Building an MSE signal kit.
I want to avoid CA if possible - it gives off very nasty fumes if it's heated and remembering what's glued and what's soldered is another problem for my remaining grey matter …… :lol:
I prep parts with a fibre glass pen before tinning but I think I'll need to get some braid to draw off the excess - "fine tinning" is something I haven't mastered yet. I do indeed tin both faces then apply heat to bond.
My "go to" solder is 60/40 but I think mine is 1mm or maybe even more …… Leaded solder is difficult to get here in France - even as wire - (at a sensible price). I'm still using my last UK supplies.
I cut my teeth on MSE signal kits.
Don`t overthink them.
Plenty of heat 60W - 80 W
A powerful flux….acid…the nearest you can find to Bakers Fluid.
Leaded solder. Hurl the 145 solder in the nearest bin.
You should be able to solder (or unsolder) with just a touch of the iron if you have the right flux /solder / heat. Even on uncleaned brass.
If the solder does`nt run it`s either a weak flux and/or not enough heat.
Twobolt John
Thanks for the "just stick the boot in" advice - that's what I tend to do now and it does seem to work. I do have some Bakers in stock but haven't tried it on this kit. I'll certainly do so - it is great stuff but needs a good wash afterwards.
