Barnstable
One station of the Devan & Summersett
Yes please Alan - but no hurry.
This a close up
Connects to a Masterswitch which in turns fires the Side Mounted Peco motor.
The other panel as shown on Jun 2 of the actual station & loop will also be modified now.
Irrespective of the actual buildings that I may use for that siding, I have decided to give it a name as I am doing the simple "panel" for that end of my Barnstable & it will be called " L+S Doors".
L + S Doors
Like it Ron :thumbs
cheers Brian
Once I convert the other 3 dead sidings of Tiverton to thru running, then tender locos can be used.
the majority of locos will be diesels - saves me a turntable.
That works nicely in British outline but how different it is for our Australian modellers. Even the most modern locos often require turning before they can lead a train. :???:
Good to see the recent developments around Barnstable, keep them coming.
Front
Side
Back
Close up of back
Sorry Ron. You were saying…?
Ron still watching, and I like the idea of the move :thumbs
The L+S Doors factory based on the photos that Alan supplied will use as a base, Scalescenes TO26 Factory- Warehouse
and for the goods shed
on this spot where the Saxa van is situated. The L+S Doors will be at the far left of this same track.
This is of course from Hornby Magazine #26 - another Scalescenes product. As I build this following the Instructions, I will take photos.
Now for carefull cutting out & gluing to card.
Top part is the original ,bottom is mine
By the time I finished, I hope it looks the part.
Can i make a suggestion
why dont you do a seperate thread for building your warehouse i dont believe we actually have a scalescenes build on here but lots of pics of totally completed ones.
It would be nice to know how you find the build
problems you encounter and how easy you find them to work with.
The scalescenes products are very good value and im sure many more members would use them if they knew how hard or easy they are
cheers Brian
