Barnstable
One station of the Devan & Summersett
I don't expect to understand that, Ron.Confused by the way that activating the crossover turns off the second green light on the bottom straight.
However, I'm pleased for you that it's finished.
Smooth running tested?
Pete, the green light indicates set for the straight while the amber indicates using the crossover - helps to define the toggle switch as well.
Reasonably smooth running especially with bogie vehicles.
A very tricky bit of track laying that's been very well executed. :thumbs
to this:-
ballasted.
Station building to move from the LH side to the RH side - cut down of course.
The RH track is the mainline and the LH track goes to the main station, Tawnton.
A new platform is underway
a close up of the underframe wood 15mm thick
now to provide the paving surface for the paving stones & stone wall as the next stage.
Wow - that must be some kind of a record Sol ………..:roll::roll:Since April 2013, Barnstable, on the lift up, has had a few changes …………………………………………………………………………………………………………
Nice ballast. :thumbs:thumbs:thumbs
Speaking of ballast, is the ballast you use from the Chucks Ballast range or something else ?
I like your fearless way with dealing with the point on the liftup section. Those Peco? crossing noses can be a little delicate!
Regarding dremel disks have you tried the diamond one,s?
Cheer,s,
Derek.
looking the full length showing the rising road base to join upto Marabost parking areas
Ken
Barney
Barney
plenty more to do…..
Fantastic job on the scenics. Very realistic. Looking forward to seeing more.
post painting to be done, then fencing, etc
