Barnstable
One station of the Devan & Summersett
Very Nice building RonIt doesn't look like card and paper, it looks more like plastic, very nice, just wish that you would spell Barnstaple correct
Just caught up with your layout Sol and I do like the developments especially that brick-faced platform you have under way. Much less obviously a download than one or two going the rounds.
The thick MDF looks to be very robust indoors as well; I tried it outside only to discover how quickly it warped :???: All the remaining exposed MDF is now coming off the layout for that reason.
Keep up with the good work and ignore all those who claim to be locals and able to spell proper
Hadn't even noticed the 'stable' v 'staple', but you call it whatever you want. It's your railway…
The spelling is designed so that nit-pickers have no leg to stand on when they say Taunton, etc was never like that so I can come back & say this is my Tawnton, etc.
The printed papers- while Scalescenes is good, I found that the USA software from Evans Designs such as Brickyard has 20 basic brick/stone printable in any scale that you desire like 1:98 or 1:31
This is another station building by my mate using Brickyard paper for the walls.
Got to go, I have an appointment with a duck-breast and a bottle of St Emilion, a sort of late New Year's Day lunch after our gas supply failure. I may be gone for some time…..:lol::lol:
Brickyard
Brickyard Brick Paper Software 20 patterns you can print in Any Scale! PC Software for Windows 7, 8, 10, and 11
Print your Own Realistic Miniature Bricks
Print all of the brick paper you need for your model train, doll house, school project, or any diorama project.
This is the opening screen where you pick your scale:
If your model scale is not listed, type it in the "other" box
Then click the pattern you want and print brick in your scale!
Here are the 20 brick patterns available in Brickyard
- Brick: both weathered and newer bricks
- a great adobe pattern
- 2 field stone patterns
- a cinder block
- field brownstone,
- grey cut stone
- and brown cut stone.
You can change orientation from portrait to landscape, or choose larger paper if your printer supports it:
We print all of our designs using an ordinary Inkjet Printer and we recommend Matte Photo Paper for best image quality.
What can you use brick paper for?
for Building Walls, Stone Retaining Walls, Brick Sidewalks, Tunnel Portals, Bridges and Bridge Abutments, Archways, Patios, Foundations, Public Parks, and any other area in your Layout, Dollhouse, or diorama, or scene that needs some miniature bricks or stones. Your own ideas!
Ruins! Made easy with Brickyard
Choose your scale, or choose a custom ratio.
Brickyard is great for N HO S O OO G, and 1:12 brick.
Brickyard is also used a lot for 1:144 1:35 1:72 and 28mm modeling.
Use these miniature brick papers for any modeling ratio from 1:12 to 1:220
Better Together!
Brickyard is compatible with Model Builder. The bricks in Brickyard will import into Model Builder as another palette to work with.
There is no overlap of brick patterns in Model Builder brick and Brickyard Brick.
Created in a spreadsheet with slabs 10 x12 mm, very light grey back ground to be glued to cardboard.
Cut to size - the card is 1mm x 6mm
Wrapped around & glued like Scalescenes products
Glued to platform front
Now to finish the edging.
If anyone wants to buy the software it is very reasonably priced at $15, …..
I was hoping to find somewhere I might buy a duck-breast with a bottle of St. Emillion ;-). Sounds extremely appetising.
A great "How to" build platforms from Sol which might need to go in our index. Thank you. :cheers
If you have curved sections, is it a case of making a straight strip and then cutting vee's on the inside edge or will you cut each stone individually?
Gordon, previously I cut out individual slabs, the next time I have a curved Platform , l I think the Metcalfe slabs will be used. I will have such a beast on the main station Tawnton & not looking forward to that.……….
I had always planned to have curved platforms but my first effort completeyl overlooked this fact !! Fortunately, some of the trackwork left a lot to be desired so up it came - now I can do it properly. :cheers
This amount done so far.
A bit of cutting for the curved ramp & odd pieces
When completed, a good clear gloss varnish again on the stone walls really to stop ballast moisture from creating problems.
A light weathering using powders all over wil then be done, then a matt spray varnish over the entire platform.
It will take me another few hours just to lay the rest of the paving slabs , but got nothing else better to do :roll:
