00 Gauge - Charde
Charde Goods shed. Scratch-built by my mate who no longer required it so I scavenged it before he trod on it.He had not finished it so I added the window framing & a support wall for the internal platform.
The other end - added corner stones for the main track entrance & cut into the external wall for a doorway onto a platform
The roof tiles was also redone from a flat printed sheet into individual tile strips.
Platform frame work done using 2mm card.
More internal supports added, a top part then covered the sides with Scalescenes Random Ashlar stone that matches the shed itself -
Yes, slightly OOF. Top to be finished with paving stones & a crane and will continue after I have fed the Inner man for lunch.
The platform is now fully paved & of course, having a curved platform helps in laying slabs exclam:
The black bead is a point operating method - a thick wire rod of about 1mm diameter connects to the tiebar of the point behind the shed next to the passenger platform.
Now for the crane.
I had to look closely to see it was paper.
Looking very nice indeed.
Someday I just might have to give this card stuff a try. :shock:
Wayne
It also looks very tough. It always amazes me just how strong cardboard models are if you use either laminations of thin card or hefty stuff like rthe 2mm.
It's such a "gentle" curve, why did you bother to add it …………………………..? :lol::lol::lol::lol:
Looks great Sol. How did you do the window/door arches ? From a Scalescenes download I presume the corner stones are cut from a printed sheet and just paper thickness. Yes - with edges marked with a colour marking pen to remove the white.
It's such a "gentle" curve, why did you bother to add it …………………………..? Because I had a slight curve in the track so the platform fits the same distance away from the rails along the length :lol::lol::lol::lol:
PHILL
Looks the part.
Making those kits saves a lot of messing about scratch building cranes.
I'm running out of little cogs!
I saw a prototype in Portugal of all places.
Not quick enough to get a pic. out of the train window.
I use Slaters Plasticard for the external covering as the papers now available were not when I needed them those years back, to change now would be inconsistent with my earlier buildings with which they live.
Many of my structures go back 40 years or so and are still in good fettle.
Both have advantages/disadvantages, currently I'm using Elmers for new buildings at Hintock and getting good results.The benefit of Slaters plasticard I find, is the ability to paint and colour it to suit the circumstances and my style.
I am with you there John, although I have to say the range available from Scalescene is starting to edge a new Laser Printer up my wish list.
Thats a great build Ron……………looks really good:thumbs
On edit - Having just typed the above, I wonder, is there still an age restriction on the sale of solvent glues in UK ? I remember once upon a time, seeing just cards on the hangers in DIY stores which you took to the till where they issued your tube/can of glue.
However, I still use their embossed plasticard as an alternative to Wills Sheets as I can make a whole building in the time it takes to saw through Wills Sheets.
I normally 'back' the embossed sheets with plain 1mm plasticard.
This gives sufficient depth for doors, windows etc. and strengthens the structure.
I do wish there was some viable competition for Slaters though.
Preferably an outfit that can cut a straight line and know where the post office is.
Last edit: by ddolfelin
I hadn't heard that DD ….As some will know, my opinion of Slaters products and service is not of the highest…………………………………….
