Johns 7mm Layout
In the orange packs are GE station seats, 3 per pack. In the yellow packs are GE platform lamps, 3 per pack. I got these from Kemilway - Kemilway - Kemilway Coaches, Underframes and Bogies
I got six plastic ground signals from Ratio in kit form and six white metal ground signals from Dart Castings. also in kit form.
I assembled one of each and the rest are now in the wheely bin because I ballsed up the first two and couldn't see the point in ballsing up the other ten.
Allan
Shame about the ground signals. Surely they didn't require anything special, just glue. :hmm I bought some ground signals from Rob, assembled and painted. :Happy
Thanks.
Allan
Sadly I haven't, John had all of them.
Regards Rob
Following discussion with a friend of mine (who does 4mm but who I'm gradually converting to the joys of 7mm.), he came up with the idea of a fishhook shaped layout:
The boards highlighted are in the process of being built. The dotted green line is allowance for my ample girth. The ends and sides require precise angle cutting which is beyond me. In fact the required ends have been cut from Russian ply and I have installed machinists dowels in them.
Next big job is to buy and cut the tops. For this we will use 3/8" good both sides ply.
The top of the picture is 20' long and the alcove is 11'.
The basement currently looks as though a bomb has gone off:
The curved modules have been partly disassembled. The lower ones to the right were made earlier and I've screwed on a fascia to the 9" insert that can be seen in the drawing. The higher modules to the left have had blue foam added to build up the width to around 2'. The foam has been shaped and I will insert 3/4" x 3/4" blocks in order to screw the 1/8" MDF fascia strips.
I built an additional 6" insert that is not shown in the drawing but can be seen to the right of the high module with a fascia piece fitted. This fits at the middle of the curve in an attempt to optimize the layout radius. The track radius should be around 5' which is comfortable for 0 gauge (4' being minimum).
The hook shape will certainly make the most of it.
Regards Rob
My motto with regard to room/space is, "nimium numquam satis est." (Too much is never enough). In my 1:48 empire, that is very appropriate. :lol:
"Room enough is never enough "
Allan
I added 1/8" MDF to the sides.
I used spackle to smooth out the foam additions and some green rattle can paint on the fascias.
I can put it all back together now.
Quite happy about this. The outside radius of the curve is ~ 5' 6" (the alcove is 11' wide) giving me something like 4' 6" for track radius.
I have to know these things you see in case it's something that I can tell everybody I invented.
Allan
You have a window in your basement? I've only bats and dusty wine bottles in mine! I suppose I could run an underground railway though.I thought I'd post and update of layout activity. Despite my predilection for kit building, layout planning has been going on.
Very neat baseboards John and refreshing to see all those curves. Looking forward to your scenics.
Bon courage,
I've been in construction all my professional life and seen many basements in the USA and Canada with windows, some high level ones and often on sloping sites, but seldom in the UK and never here in France, where it's the reserve of wine and mushrooms Sorry, it's just my sense of humour (and sometimes sense of the ridiculous) and my tongue was firmly in my cheek!
Well done also on such a tidy work space!
The first two boards are 4' long, tapering from 18" on the right to about 4' on the left. There's a 4th short board to be done yet.
Progress!
Last edit: by Brossard
