so they have been plonked ready for some draft positioning . The actual anchoring will be on a 3mm base to enable full scenic work to be done off -layout before re-setting back into the space.
I see he likes his chimneys!
Usually I really love your modelling but the stuff in this shot looks absolutely cr#p. If you send it up to me in France, I'll try to find somewhere out of sight for it on my planned layout - I'd hate it to spoil yours ……………..:roll::roll::roll::roll::roll::roll::lol:
p.s. Would your train controller mate like to be my mate as well ? :roll::roll::roll:
The signal is from the Eckon range & indicates not only the point leaving from the storage but the status of the Mainline past Barnstable which is around the corner past those low hills.
Thanks Sol :cheersAnd for those who maybe interested, attached is a basic plan of the D&S.
There are storage tracks behind the station named Tiverton.
the early days.
So I had thought of hiding them so by using 200mm high 5mm thick MDF, I have created a viewing block ( to be painted the pale blue)
tunnels mouths to be added at each end.
A view over the board…
How will you access those storage roads Sol ?
Craig SR
Glad you left the tracks in. I bet it gives a different perspective to the layout having those tracks now hidden.
I had to instal 3 IRDOTS before I contemplated hiding them so I got IRDOTs with 2ft leads for the emitters & detectors as fitting IRDOTs directly under the tracks as normal was almost an impossibility due to 2 lots of shelving under the layout.
I now can determine which track has a train stored in it so it helps to prevent driving another train into one already stored.
at the far end of the above photo is Metcalfeville
as one can imagine, a lot of work in that area. I think about job # 983 on the list.
In fact Tawnton itself will keep me busy for a loooong time.
temporary tracks to give an idea
now installed
now sleepered & painted
The entire brewery area will take some time in buildings, etc to give it a "proper" look. Job Number 1004 I think.
That extra siding makes a lot of sense and gives additional "operating potential". :thumbs
Trouble is Peter, the crew want more money as there are more tracks to work exclam: A bit rich I thought as the crew member requesting an increase in pay, was the one suggesting the extra track.That extra siding makes a lot of sense and gives additional "operating potential". :thumbs
