:doublethumb:lol::lol::cool:
I like the small local panel idea
Chris
This shot also shows where the train orders are retained - on the end of the centre peninsula.
Can you explain what the green metal bars that go over the storage sidings are for? Apologies if you have covered this elsewhere. Also I have been thinking of using some of those side mounted Peco point motors for some areas of my layout. I would be interested to know how you are getting on with them. They look quite neat in position and will be even better once the ballasting is in and they are weathered.
Bob
Craig SR
Looks like you will have loads of fun and interest in the coming years as you continue the build.
Derek
Can you explain what the green metal bars that go over the storage sidings are for? Apologies if you have covered this elsewhere. Bob http://yourmodelrailway.net/view_topic.php?id=7607&forum_id=52&page=4 Post #70 onwards Also I have been thinking of using some of those side mounted Peco point motors for some areas of my layout. I would be interested to know how you are getting on with them. They look quite neat in position and will be even better once the ballasting is in and they are weathered. Yes they are neat & Rick/Gwiwer also uses them. They do take a bit of just getting them right mainly in levels . Itis a pity they don't come with a changeover switch built in.
Bob
I am very happy with my Peco side motors. They are easy to fit, reliable, can be blended into the running scene as point motors (see my own layout thread) and if necessary can be replaced in just 5 minutes with next to no effort. That's between trains for some of us rather than between sessions.
They don't like being misaligned so it pays to get them perfectly level and with the throw at exactly 90 degrees where at all possible - though they will work equally well on Y and 3-way points where they have to lie alongside curved track and throw at an obtuse angle.
Please also see my posting today on John Dew's thread about a 9" grid, I meant to make it earlier here when you were track laying.
Thanks for the explanation and link to your other thread - now I understand! I am now going to use the side mounted Peco point motors for my MPD, which has tracks running underneath it which prevent under baseboard mounting of the motors.
Bob
caused some problems with loco interchange so I decided that the DMU depot at the other end of the station was to go.
I have revamped the storage to have the DMU's based there so the MPD will come to this part, extra tracks required.
The existing MPD this morning looked like this
is no more & looks like this
The space will be used for scenery like houses, etc on a 3mm base so it can be built off layout & then placed into position - job #895
Paint it the tan colour tomorrow to clean it up, then modify the panel.
Craig SR
A couple of diesels sitting there now. The 2 point motors on the 3-way to be relocated tween the tracks; the existing tracks - two off, to be moved to suit the MPD building & then another loco track plus Fuel/Service track to go in.
The additional 3-way was surplus from the old MPD so it is being put to good use and you can see why the existing motors have to be moved.
Rare earth magnets installed into the two left tracks.
Now for the revised panel-
This is as it was - the DMU service tracks now the MPD so additions to be done to this.
cheers,
Derek
Last edit: by shunter1
