I rarely get to look at the Home Page, as I usually go in by the email links.
D&S Layout very nice, I like your re build plan, s. New ideas always welcome.
Had you found place for Mill Wear House, Last model build.
Up Date plus pic, s please.
Best of Luck From South Wales U.K.
Noviceman.
I haven't built the Mill warehouse - I was just advising all of the new release - I have no room for it….
Hi Ron. The "Fun" with code 83 and code 100, was that "Tongue in Cheek"? And did you have to use a file??All the best. Kevin
Solder a code 100 metal fishplate to code 100 rail for 50% of the fishplate length, flatten the other 50% & solder the code 75/83 rail to this flattened piece of fishplate ( with the inside edges of both code 75 & 100 in alignment.)
A file just to touch the top surface up.
Noviceman, there is a N scale version on this postHad you found place for Mill Wear House, Last model build.
Noviceman.
http://yourmodelrailway.net/view_topic.php?id=15110&forum_id=21&jump_to=273256#p273028
this one shows all the wires but they are very hard to see normally.
this is basic as of now
planned & with signals & interlocking, crashes at the diamonds should be few & far…(hopefully)
as I have a NMRA meeting at my place May 11, after that is when I start the track changes ( existing scenery removal can start now… )
Looking forward to it. Presumably all the main buildings will remain as now ………………….. :hmm
I think minor changes at Watchit - I think…..Wow - that's major works Sol.
Last edit: by Marty
As I have turnouts interlocked currently between Devan & Bruton Jns, I can interlock the turnouts at XXXX & YYYY,
star to starso while the purple track gets used for two different routes
, this means a lot less work than having so many diamonds and 3 tracks across the liftup which I must admit I was not sure how to do it without completly ruining Devan Junction .
Good luck with version II
