Members Monthly Project - April
(In Topic #6198)
April project questions and comments here please.
All your questions on the April project to go here please.
Not this time Stu - the brief is to keep it simple!!Looking forward to this Geoff, will there be any logic diagrams as well ? :lol:
Wayne
Is it OK to use these for running LEDs, or are there problems with this idea quest:
Not knowing what a 1 Ohm resitor looked like (the colours, not the shape…) I found this website : Resistor Color Code Converter
I could not find anything in the YMR index.
Stu
Exactly my point….:oops:
Les
Devon Junction
Kernow Junction
Kernow Junction
ive got some station ones to do so i will watch Geoffs progress
Some station ones already done here but apparently not correctly as they seem to be a bit warm and trip the transformer after a minute or two.
That doesn't sound good, Rick. What type of station lights are they - bulbs or LEDs. Also when you say transformer, what have you actually got powering them?Some station ones already done here but apparently not correctly as they seem to be a bit warm and trip the transformer after a minute or two.
The platform lighting is unbranded but supplied in packs from an eBay seller "everydaygoodz". They were advertised as and supplied in a bag marked 12vDC. They have small rectangular lamp units which seem to emit the light from a glowing wire and are definitely not LEDs.
They are wired in parallel back to one of the cheap Hornby train-set type controllers which can be picked up for a few units of local currency quite readily. The output is quoted as 12vDC.
The controller has a rotating dial which will regulate the speed of trains were it connected to the track but does not regulate the brightness of the lighting. It is either on or off. When it is on there is a faint but distinct smell of something being warm and after around 2 minutes the lights cut out.
They can be restarted but only by disconnecting the output and allowing the transformer to reset itself. However because the lights remain warm when power is reconnected they will trip again in a few seconds.
