What to do?
(In Topic #13742)
After trying out 009 on my test plank, I've now decided I'd like to have something where I can just watch the trains run round (especially since I have two Bachmann Baldwins with sound).
I could have a little loop with a few sidings…
.. or I could do a folded figure of eight…
I'm open to all help and suggestion, but maximum size is 4' x 2' (1220mm x 610mm), and preferably slightly smaller.
I don't really want to go go below 9" radius curves, or an incline of more than 2% (1:50), also due to the Baldwins.
Last edit: by Ed
I agree. Go for the top one!Ed, while the bottom folded plan gives a longer run, I prefer the top plan as it involves more train shunting as well as having a loop to be able to sit with your glass of red and enjoy.
Bit late to this one.
The first plan with dividing back-scene only gives you 50% viewing or operations at a time. Which sort of goes against what you seem to be looking for (watching the trains go by).
The second plan means that a good proportion of the track (somewhere between 10-12 feet) will be on an incline. Why not use a diamond crossing rather than an elevated crossover? Or even a double slip (or its equivalent using a diamond and a couple of turnouts). This would allow running on the outer, on the inner, or on both. The inner track is less than 9" radius as well. How about increasing the width and decreasing the length a bit?
One of the limitations of OOn9 is that although the track is N-scale, the stock is not. When I was doing this I used OO or HO track plans, with adjustment for the narrow gauge track as appropriate. Basically somewhere in between. Trying to compress an OO layout on an 8 x 4 to an OOn9 on a 4 x 2 didn't actually work.
Initially I though you were planning an N scale layout given that the second plan is more of a mainline looking railway than a quaint narrow gauge set up.
If that is the case and (a) you are limited to a 4x2, (b) you want to see trains roll by © you want a scenic divide and (d) you might want to dabble with shunting, might I suggest you (or anyone else reading this in N scale) consider the following from Atlas track plans . To wit…
and perhaps modify it for left hand running by reversing the plan if necessary for you. The offset of the track at the back would give it a visual interest and I made it a must for my own (relatively) small layout and wish I had done (or been able to do) the same at the front of the layout. Unfortunately I have not updated photos lately and there are few of the back of the layout but I will get some done soon.
It's double track? Ok single track it with the single passing siding on the left or right - your call it is your layout - and allow the bigger running space with a smaller yard, not necessarily too long but more than adequate for your stock and a bit of shunting interest… if you change your mind!
Cheers from Australia
Just following through on the pictures, here is a Budd RDC pair at the back of the layout in several positions to illustrate what I was talking about…
The gentle curve back provides a bit of visual interest and certainly gives the impression of a bigger layout if only in pictures. I took a number of pics of the layout in its early days minus the backdrop in place now and many people I showed them to were increduluous when I told them the size.
As I said earlier I would have with the benefit of hindsight put an outswinging 200 plus inch redius at the front rather than the straight section! On a smaller layout as you are planning where the eye can take in the whole layout, it may look exaggerated so I would suggest reducing the curvature a little but keep one just the same!
Hope this helps someone if not yourself as an idea!
PS, Near the roof of the cabin which you can see in the last pic (the greyish "triangle") I had a figurine of a guy lazing as though sitting on the grass, watching trains… that would often be my eye view as well or close to it!
index02
index02
Hope it's just bruised and that you're soon up and about again.
The back is improving, but it's just a case of resting and not moving about more than is necessary.
Took 3 months for the tail of my spine to stop aching.
Thanks Marty, something to look forward to :lol:
Actually it's not quite so bad today, but it's very frustrating not being able to do much.
Look on the bright side though, it gives you a bit more time for the planning.
Just for what it might be worth for your track plan, may I suggest two loops with a cross over and points to get you into sidings. That way you will get the best of both worlds. Trains running round and some shunting.
I hope you feel better soon and it is nothing serious.
Gary
I'm on catch-up duty having been away for a bit and am hoping your back is at last easing up.
I've been an occasional back sufferer for decades, after an incident on a snow covered mountain and then, like Marty, had a bad fall needing three months for my bruised cocyx to ease.
Slow and steady Ed, hope to see you soon.
…..says he writing in a reclining position after moving one barrow of topsoil too many this afternoon…..Take it easy…best wishes
It's slightly better, but still can't move around much.
