Trying out N Gauge
(In Topic #21591)
4' x 2' small layout
I started looking at the possibilities of a small N gauge layout over two years ago, but with domestic issues, my mobility problems and then a bereavement, it all got put on the back burner.The board measures 1220mm x 610mm and is a left over from the OO gauge garage layout.
I stuck some 2nd radius cuves down to make an loop and didn't get much further, but after a bit of work on the test Z gauge Noch layout, I fancied something a bit bigger.
It seems many Graham Farish and Dapol locos require a minimum second raduius curve, and to have two circuits on this board the inner would have to be 1st radius.
Second radius on Peco sterack is 10.37" but I was wondering if I'd get away with Kato 9.8" radius for the inner loop and Kato 11" for the outer loop, which I might just be able to sqeeze on to the board.
Not sure f I need the trasition tracks or how happily peco points would fit to them.
I know Mike (Dorsetmike) is using afew bits, but wondered if anyone on here had used their curved tracks and if they had any running issues.
It is a bit near the edge, but I might be able to add something round the sides, just to try and avoid anything taking a nose dive if it does derail.
I've no experience with anything other than Peco track.
A backscene will stop the nosedive to the floor.
Have fun experimenting.
I look forward to seeing what you come up with.
ATB
Don't have to squint to try and get a couple of fishplates to line up as the plastic clips do it for you.
It's definitely too near the baseboard edge though.
I'm either going to have to attach an extra bit of baseboard around all the edges, or get a new baseboard.
I'm was also pleased to find the points come with extra bits of track, including these two small straights which have the ballasted trackbed shaped to fit, no more trimming sleepers to get the diverging track to fit.
Next test is will the locos and stock negotiate the slightly smaller than 2nd radius curves without derailing.
But the outer loop really is too near the edge.
I'm still debating baseboard size/options and track plans, meanwhile Bob K of this parish did an interesting thread on his layout Tempsford, which shows how to improve the look of Kato Unitrack, if anyone is interested.
N Gauge Tempsford – Your Model Railway
Last edit: by Ed
For anyone that isn't familiar with either of these layouts, this is a link to Lymebrook Road below, and a browser search of either will produce some YouTube videos.
Lymebrook Yard – Macclesfield Model Railway Group
Both layouts however employ very tight curves which I wish to avoid, so I've ordered a 5' x 2' 6" (1525mm x 762mm) baseboard which is probably about the biggest size I have room for and can also physically manage.
I'm going to use Kato track and have come up with the following plan.
The orange rectangles represent the visible parts of the station platforms, the imaginary rest being hidden under the raised Scenic section.
The blue and green rectangles are some sort of rail served industries and/or maybe a goods shed.
The long blue strip could maybe be a river or canal.
Nothing is set in stone yet.
Maybe
😁 Ed
Some people have also has derailment problems with the #4 points, so I've changed the plan to insert a short straight between the curves and the points.
The industry might be a brewery as I've seen some quite nice Kestral models that might fit.
Brewery Main Building Kit-Kestrel-GMKD1006 | Gaugemaster (gaugemasterretail.com)
Brewery Boiler House Kit-Kestrel-GMKD1007 | Gaugemaster (gaugemasterretail.com)
Kestrel kits are a bit pricey, so I'll have to shop around.
Unfortunately everything in this hobby seems to be getting more and more expensive.
I'd like a continuous-run layout of some sort, but nothing too large, so N gauge would likely fit the bill. My eyes would limit it to being more of a 'watching the trains' layout than operational/shunting (for which I have my OO inglenook) and I'd probably have to rely on ready-to-place structures and scenics.
Will be interesting to see how this one develops. Best of luck with it Ed.
~ James ~
