Wills and Ratio plastic
Tools for cutting and shaping
Hi Brian. This is another reply. I have located my local “Range “ outlet, at Surrey Docks ( now known as Surrey Quays ) . I have a choice of Train or bus no contest. When I am up to it, if they are still trading? I will pop along and see what they have. Best wishes Kevin
http://yourmodelrailway.net/view_topic.php?id=5042&forum_id=11&highlight=scrutter
Wills sheets are probably the most difficult to work with and in my view the depth of relief on the joints on their brickwork and stonework is totally unrealistic to the point of looking cartoony (and that's being kind). At the distance we generally view our layouts from relief is not necessary for most walls constructed in brickwork, although I do accept many modellers like to see some.
So look at Slaters or Southeast Finecast as an alternative to Wills, or better still, use card and Scalescenes textures instead: easier cutting and save on painting.
Last edit: by pnwood
A decent heavy duty utility knife and blade will score Wills sheets and then cut them with a bit of patience. The trick is to cut slowly and repeatedly, and only about a third of the way through. Then put a thin piece of cardboard under the the section you are holding, bend the sheet open a tad at the cut, and continue cutting. Bending just slightly relieves the pressure on the blade. Good neuropathy exercise.
If you cut out or score about half way through and then put it in the freezer for 30 minutes it will snap more easily. Wills plastic is too soft and pliable at room temperature. Always cut oversize and file/sand to the size required.
A carpet or lino cutter knife blade works as well. I use an old dart as a scorer, tapered end, sharp, no filing required. A modelers saw and multi-angle box is useful when you need to cut things at angles or for small pieces that will not snap. These saws have minimal kerf and do not seize.
I did point you in the direction of SE Finecast sheets a long time ago when you were exploring embankment and abutments.
