Paper or Plastic?
(In Topic #7731)
or wood or plaster for that matter
No - I am not practising for a job on a check out!I was wondering what people prefer to model in - paper, plastic, plaster, lolly sticks etc.
And importantly why?
I know we have some excellent card modelers on this site, and over on RMWeb (is that a swear word here?) there is a guy modeling the whole of Manchester picadilly in plasticard including some awesome viaducts.
What are the pros and cons of each.
Not looking to start a fight or even a heated debate, just looking for information.
If it aint broke - I did it.
If it is broke, then….
Plastic is easy to glue but larger sheets tend to warp very easily. It's also quite expensive.
Probably the main reason for my starting to use card were the excellent offerings from Scalescenes. Then, slowly, I began to see some advantages over plastic. Now, the only disadvantages I can think of are that it's not an "instant bond", it's only 2D and, for me, it's the very devil to get a decent bend in it without any kinks.
For scenery (landform), it's some form of plaster for me every time - over wire netting. :cheers
All the materials you mention have their place and I suspect, most are used by everyone from time to time.
I remember seeing a write-up on RMWeb (I think) about a guy doing resin castings for a model of York station. Knowing the station well, I can tell you he was doing a pretty good job. :thumbs
I have to say I prefer my buildings to have some texture, but scalescenes are awesom buildings Which has revitalised card building as I remember having met calf and super quick when I was a kid which haven't really changed much.
thanks for your thoughts Peter.
As far as landscaping goes, I haven't done any for years (my layout is still in the head stage)
I used to be normal until my grandson discovered model railways
The definition (and longevity) provided by plastic is important to me.
In any case, even cardboard users would have to resort to plastic or metal if they want to populate their layouts.
Peter. I find that Roket Card Glue gives instant grab for card. Expensive but useful.
At the end of the day I guess it's a matter of whichever material I feel is best suited to the task in hand. Much of my stuff is a mixture of two or even all three materials.
http://www.finetip.co.uk/
A fantastic little gadget that I simply wouldn't be without.
I've been very impressed with some of the Das clay effects Bod but I'm not sure I'd have the patience to use it much. A bit like the "Linka" system I have (WFsites) - Page not found It's good but very slow.
I use paper and card, but I am not so hidebound as to ignore the benefits of plastics, such as the availablity of fine sections, rods and strips or its ability to take scribed detail.
'Anita's Sticky PVA' glue makes an almost instant bond with most card. I prefer to use a material that is in plentiful economic supply so that in the event of a coc&-up all I have to do is eat more Corno-Flakos to realise my next supply!
some practitioners still inscribe mortar lines that a scale sized guinea-pig could hide in.
I suppose it depends on how delicate your tool is.
All my landscaping is plaster over the 'dreaded' carved styrofoam. This method allows me to build up layers of plaster for creating textured surfaces, ie in cuttings. All my larger retaining walls are cast plaster with those scribed 'guinea pig' motor lines. I find I can colour the plaster with a few washes to get the desired tone of brick or stone easier than using printed card , embosed plastic or embosed card.
HTH
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
And when the bricks are 100 years old, rounded by errosion and most of the motars gone? Its not what i 'expect' to see its what i 'do' see.
You might getaway with it in N but in 4mm scale not only do you need the textures of bricks you also need the textures of things like concrete etc
See rule 1 in my sig :)
Jim
Last edit: by jim s-w
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
The distance that affects real world also affects models :)
Been advocating suede paint for years, see below :)
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Jim
Jim…..you have been warned before about posting pictures of real roads at 0600 on a Sunday morning and dropping in those obviously fake model room backscenes….Stop it! :)
