"No-Nails" et al...
(In Topic #13756)
Caution
This is just a quick post to say that if you are considering using 'No-Nails', 'Gripfast', 'Gripfill' et cetera to glue together layers of hard expanded foam sheets for baseboards and scenic landscaping, be very sure that you won't have to cut into the layers through the product after it has gone off.Today I started cutting into my baseboard to plant my road bridge. Blimey! I had to use a hacksaw blade and a fine pull-saw to get through the adhesive layer. A Stanley knife wouldn't touch it, and a firmer chisel struggled, it was like trying to cut bone.
Needless to say, I also used what oozed out to coat the bottom of my 'river', I think an abrasive disc will be needed, I'm dreading SWMBO's reaction to the inevitable mess!! :shock: :shock: :shock: :pedal
Poop-poop!
There are not many products suitable for glueing styrene based sheet material so maybe multi thicknesses are not ideal. I wonder, would "plots" have held it or did you use and overall coating ?
However I do find it is the best adhesive for fixing hard expanded foam (Celotex, Kingspan etc)
Shaun.
Peter, you know me, if you are going to lay it on, do it in thick layers, like flattery. [Older ladies will accept it still with gratitude, younger ladies will instinctively know you are exaggerating and think you a kindly lecherous old buffoon.That's worth knowing Doug. :thumbs
I'm happy in either camp….
Douglas
It's not expanded foam, that's the crumbly stuff, that turns into bubbles, the celotex, kingspan, etcetera are EXTRUDED foams, that type turns into dust if you saw it.Agree with Doug and Nigel!
Shaun.
But yes the no nails type glue is the best for the task, I generally use the non solvent versions as I use expanded foams for some tasks. They dissolve with the solvented glues.
Oh Celotex is not styrene it's Polyisocyanurate
Last edit: by The Q
As you say, it's cheap as chips and very versatile. I use it for a multitude of things around the house but never thought of using it as a glue …………………… :hmm
:oops: Stands in corner with corrected hat on… :)[user=567]gastwo[/user] wrote:It's not expanded foam, that's the crumbly stuff, that turns into bubbles, the celotex, kingspan, etcetera are EXTRUDED foams, that type turns into dust if you saw it.Agree with Doug and Nigel!
Shaun.
Douglas
