Twobolt John`s winter regression loco build
I particularly like the opening windows.
Regards Rob
I always enjoy watching you builders put together kits and marvel at the engineering involved to get them working.
thanks for showing the steps in the journey.
ThisPug kit is all but completed now, just the brake pull rods to fit.
I ran her in a bit on my rolling road today and she was floating up and down on her front axle springs due to all the weight on her rear axle.
Being 90% whitemetal you would`nt think she needed extra weight , but her front end was too light and I decided to add `liquid lead` to her front `footplate boxes` and then add sheet lead to her smokebox to balance out her movement.
She will go into temporary storage until the warmer weather as I need strong light to spray paint her and that will be done outside.
So I`ll post this youtube link showing her at crawling speed. Seeing that she is a 37 yearold kit with an open frame motor, I`m quite pleased.
She is controlled with my trusted AMR hand controller which is about 8-10volt max and is my `yardstick` prior to wiring her to a ZIMO MX645 decoder.
I`ll return when she is fully dressed……………………………………………
Twobolt John
I suppose it has to be done in the end .
Well folks, she has finally left the Paint Shop……….
Still needs couplings and sandpipes……………………………………………………………..
Twobolt John
Last edit: by Brossard
Loverly stuff.
No LMS layout at the moment
She underwent Anologue trials today on `GWR` metals……..
All sing……….
Twobolt John
That damn song will be stuck in my head all day now. :It's a no no
Very nice indeed, although if you could keep the layout from moving around like a tree in a gale when you're trying to do some filming I wouldn't get vertigo.
I watch this sort of thing with the sound off - no risk of songs in the head all day. My problem is I start thinking "I've got a spare shelf board, get that 7mm Bagnall fixed and running, lay some track…". Get thee behind me!
Twobolt John
Hi John,….and push Nigel?
Not with Gemma and Jude pushing the other way.
