Kadee couplers
(In Topic #13640)
http://cs.trains.com/mrr/f/88/t/278227.aspx?page=1
especially this post
Harrison, the box spring is designed to "only" to be installed "on top of the coupler". If you look closely at at the spring you will see a big difference in the spring arms. As mentioned, there's a strong and weak side to help with uncoupling and delayed action. Also, note the end of the shank on the #5 type of couplers have different angles that are not symmetrical and these match the different spring arm angles. This is why it's important to always have the spring on top. If the spring is installed on the bottom it may work OK but eventually there will be problems. Note that when the couplers are coupled and in operation this takes the centering spring out of the performance issue so the spring on the bottom has no affect. It's when the coupler has to be uncoupled and centered properley that problems will arise and the spring may wear out faster. Remember that this is all late 1950s technology which is still the most popular in our coupler line, presently even more than our whisker couplers.
Sam Clarke R&D Kadee Quality Products
The article about fitting knuckle couplings to UK stock is very useful - now saved for future reference so many thanks.
I'll naturally read it again but I'm not absolutely clear about what he meant by "compatibility" with botnh E-Z Mate anf Kadee. Did he meant one could use either or without any compatibility problems or did he mean that, after any necessary modifications to stock, either type could be fitted - i.e. no difference in modifications regardless of which coupling one was using ………………..
I've had to contend with most variations on UK stock, some easy to modify, others a real PITA and, until recent models, almost none without some kind of modification.
I suppose, give that UK is the only country in the world modelling "OO" gauge, 4mm scale, it comes as no surprise that we Brits like to be "different" ……………..
My local Mr Fixit (Pete) is just back from the UK and confined to barracks for the next couple of weeks. Not long enough some would say! :lol:
So I am teaching myself the intricacies of the Kadee system and the article has been useful. I can already see that I am a bit overcautious and have the knuckle too far forward.
Evan
I've added the latest link to all your earlier reference materials here.:cool:
Colin
Oi, I've just read that and I'd like everyone to know that I'm on the loose again. That coupler looks like it might not be far enough forward for tight curves. Fingers crossed. I'm actually enjoying seeing things take shape as I have a bash at scenery. Not much yet but I'm getting there. I love the Kadee couplers and have started using 3mm cube neodymium magnets for uncoupling. Much cheaper than the genuine article.Thanks for the article, Sol.
Evan
This in turn has inspired me to plan a shunting layout of my own but in OO gauge - hence the Kadee link. I think they are absolutely superb - I love them! I'm planning to use the neodymium magnets for hands-free uncoupling and since I am a rank newcomer when it comes to building layouts will start with a simply 'Inglenook' style shunting puzzle to gain experience (and hopefully some capability too!).
Most of my stock has NEM sockets, so the conversion process is relatively straightforward. The two most valuable pieces of equipment I have for my couplers are the height gauge and the pliers to bend the trip wire!
