Johns' 7mm Workbench
Great job. Great workmanship.
Allan
Great shed!
:cheers
I always make sure my doors are the right side up….
Andy
Andy
O6, workshop equipment. This will go into the Engine Shed.
O3, shed accessories
O16, chairs. I think these will look good in the signal box.
O15, signal box interior. Lots of neat stuff. I won't need the crossing gate wheel.
O14, stove. Not sure yet where I'll put this.
Allan
Nice looking gear. The clock is a nice touch.
From the empty space on the etches that's a lot of (expensive) brass that went down the drain.
Me too, sometimes I make more from the frets than I do from kit parts…I do like etched brass. I always keep old frets as the brass on them can be useful for other things.
Regards Rob
You two must be miracle workers, air into brass. Those etches were clearly designed when brass was cheap. The upfront cost of an etch is high, once the master masks are made it's all gravy.
The guard is in anticipation of the Dapol 20T BR brake due in the shops any time.
There are two loco crews with RH drivers for my friends 8750 Pannier and in anticipation of a second loco, probably 14XX/48XX.
Signalman who will reside in my signalbox.
Allan.
I mostly use acrylic but the blue is Humbrol enamel. When using the wash, you need to be careful because if you mass about too much it will remove the enamel. It won't touch acrylic of course.
I also tried to use as many different colours as possible with the crews, even giving one of them some stylish sky blue overalls.
I'm OK with these because they look good from normal viewing distances.
Last edit: by Brossard
Allan.
They look great. For those in the UK they will do personal scans of and you can drive your own trains in 1:76 or 1:43.5. There is an outfit here in NY that does the scan and 3D print.
Does this suit Allan?:
The things I do for mates :roll:
Allan
https://scalescenes.com/product/r025a-water-tower/
I made the windows from 0.060"x0.060" Evergreen strip.
Door is an offcut of Evergreen 0.040" sheet. I scribed it for the planks and then sanded to get a representation of grain. Door knob is the ubiquitous pin.
