Johns' 7mm Workbench
(In Topic #11947)
It got me thinking and then I realised that the Dapol Class 08 shunter was imminent and did some research. There's a version in plain green w/early crest and sound on board. For me this was less than 300 pounds and seems great value compared to other offerings from the likes of Lionheart. So that was preordered.
I've been looking around and doing the research on suppliers. Tower Models have a great selection but they're not an online retailer and seem a bit backward so I'll give them a miss. Kernow seem to have a good 7mm selection and I ordered some Slaters embossed brick and roof tile sheets.
First off, I did a swap with my friend and acquired the kit.
Next, I went to C&L and got myself:
- 8 M of plain track
- Turnout kit which includes ready made common crossing and planed blades. Quite pricey but I won't need to do that again since I plan to do all that myself for future turnouts. There's a quite nice tiebar kit from Ambis.
- Roller gauges, plain track gauge and back to back gauge.
In terms of layout, I haven't got a huge amount of space but I think something 12' long can be accommodated. I've always admired the work of Chris Nevard and his Catcott Burtle is quite lovely. It features a halt, a small goods shed and various other things - all in a small space.
So, waiting for parts for other projects, last weekend I sat down to work on some buildings that I can use for the prospective layout.
First up was a small goods shed. I used the Scalescenes kit (R002 - which I don't see on the website…odd) as a basis.
I realised that I needed to use use textured walls since printed clapboard wouldn't wash in 7mm. I used Evergreen 0.08" spacing clapboard for the outer walls and 0.04" for the inner walls and roof.
Here it is in more or less the state it would be in as built:
I made the plastic parts from the templates that come with the kit. The kit prints were enlarged by 176% to get 7mm.
Corners are 0.04" strip as are the doors. For the doors I scribed planks using my Olfa carpet cutter and made a representation of wood grain by dragging coarse sandpaper from top to bottom several times. I glued a cross piece on the back and then drilled for 0.045mm NS wire to represent carriage bolts. I also scribed the roof panels to mimic those in the print.
I did leave some paper printed parts - the brick piers and platform.
Gutters were made (laboriously) by grinding Evergreen 3mm tube to a half round. I glued fine strip around the gutter at intervals to represent bracketing.
Downspouts are 2mm brass tube bent as required. I soldered some 0.032" phosphor bronze strips to represent brackets and the tails of these were inserted into holes drilled in the wall.
Let me know if I left anything out. This is by way of experiment to see what works. I think it came out well and it will be distressed in the future.
Next I wanted an office for the goods store and it was Scalescenes again, this time the weighbridge/coal office (R024). This is actually a free kit.
This time, I built the kit from mostly prints to see how it would look:
I think the window gave me the most grief. I made the frame from plastic strip and managed to do a reasonable job. I left the gutters as the kit intended but did make downspouts from brass tube using the same method as above. The chimney is a whitemetal example I found in my collection of 4mm pots. It looks right I think. I flashed the chimney with masking tape.
Finally, another freebie, this time from Fine Scale Buildings - a lineside hut.
The kit is very nicely designed - instructions run to 12 pages! Again, this is made almost entirely from the prints, even the downspouts and gutters.
I think this makes into a very attractive model. I liked the base so much I made another for the goods office. Oh yes, the door handle is a pin painted brass.
I used signage from the above building to make this a coal merchants office.
I have a 4mm halt from Ratio or Wills so I will have a go at scaling that up.
Exciting stuff!
We'll all be moving up a scale if we see much more of this stuff John. It is a fabulous scale to work in if you have the "eye".
I noticed Hattons did a mail-shot on some of the Dapol 7mm offerings and I was very surprised at how reasonble the prices were, particularly when you think a decent 4mm loco will set you back around £120 to £130. Ok, yes, that's for a mainline loco but I think I might rather have a 7mm tank engine than a 4mm 4-6-2. It would certainly be a close run thing, provided the 7mm job was a "model" rather than a bigger "toy".
The buildings look great and I think you're right about needing relief at 7mm. :thumbs Love the little "Office". The only thing that struck me as looking slightly odd is the slating on the "G. Burrows" building. It could be the photo but the rows don't look even …………:hmm
As for the slates on the coal office, you are right they are not even. The red dotted lines on the base were not evenly spaced and I foillowed those - I think (hope) it's deliberate.
Went to Michaels today and got myself a load of basswood - I'll use this for the halt.
I'm not concerned about that really, I just wanted my halt to look reasonable.
The sketch should clear things up. Construction consists of alternating lateral and longitudinal trusses. The real thing was 700' long! I'm looking at accommodating a single coach, maybe two if the second is a brake.
I had wanted to use basswood but a trial assembly with CA and PVA proved to be unsatisfactory. I used Evergreen styrene instead. The crosspieces are all supposed to be angle, however, I could only get one packet of this. So I put the angle where it will be visible and plain strip everwhere else. Just as well since the angle is about 0.010" thick and very flimsy. I made a number of jigs from card to hold everything in place while the glue dried.
I've cut the platform deck from 0.040" and 0.020" sheet to try to get close to the real thickness of 3". I scribed the 0.040" into scale 9" wide planks and glued this to the 0.020" sheet. I also rubbed the top deck with coarse sandpaper to get the grain.
Welcome to the wonderful world of 7mm. There is some nice Lima stuff still around. Bachmann Brassworks is I think associated with Tower Models. Both are San Cheng built I believe. Don't forget Heljan O scale. Ixion did a superb job on the N-gauge Manor, they did a very nice Hudswell Clarke 0-6-0 (second hand these days).
Wonderful range of kits still available.
Bachmanns stuff seem to emulate unicorns - few to be found. I'd love to see Hornby and/or Bachmann follow Dapol to produce reasonably priced RTR. I see Dapol have formalized their relationship with Lionheart and seem to have amalgamated their ranges. Some lovely GWR panniers on offer.
The piers are longer than needed - the drawing shows them sunk into the ground, perhaps I'll use some foamcore board as a base.
I had second thoughts about the length and increased it by about 7 in. to 33" overall and 21" over the passenger portion.
According to the drawing the deck is 9' and 3" thick. I laminated 0.040" and 0.020" sheet to get close to that. The top was scribed for 9" planks and then coarse sandpaper was dragged along the length to simulate grain.
I still need to make fencing for the back and some sort of shelter. Lamps and seats will be needed too.
Do you have plans for a black wash over it - or something?
Just caught your earlier comment regarding gluing basswood. It can be glued successfully with both CA and PVA (white) glue), as well as contact adhesive (UHU or similar), but the surfaces to be glued require a bit of preparation. For CA apply thin type to both surfaces, wait 30 seconds, then glue again using thicker CA. For PVA it seems to benefit from a light sanding, with PVA on both surfaces, but it needs clamping. Yellow wood glue (aliphatic resins) is better (and much stronger) but it still needs to be clamped for at least 30 minutes. 7mm scale means you'll be able to use bolt heads, washers and nuts (at least on the visible side). Grandt Lines has the gear for this.
A 3" thick top and 8'6" width planks sounds like old sleepers sawn in half with the edges trimmed. Any evidence of chair bolt holes in the photos? The one I modeled in 4mm scale had the holes and the outlines of the chairs (old dart points have their uses).
I don't have any photos of the platform, just the drawing. You may well be right about the holes and I shall be looking at that later.
I'm still dithering in my mind about the sort of platform I want/need. The platform I have built seems a bit short - suitable for just one coach as it stands. Must do more tooth sucking.
I did find a potential source of reasonable priced coaches: Home and left a message about terms for shipping here.
These kits do make up into very pleasing models, despite the lack of texture. My thinking is similar to that of my first layout where I built a number of Superquik and Metcalfe buildings initially to get things going. Later on, I rebuilt most of these in plastic using scratchbuilding techniques. I like the idea that the kit designers have done the architectural research since I haven't a clue. These buildings will do for a start.
There are some elements of the building where texture is a must and I spent quite a bit of time effort on these. Window and door frames and doors were made from Evergreen plastic. The shelter front and back walls were made from Evergreen clapboard. The shelter front was quite taxing but I got it to be acceptable eventually.
Chimney is W/M from Dart Castings.
Looking good. One thing to keep in mind: A 0.25" setback in a mortar line between bricks is 0.145mm in 7mm scale. Most railway structures used flush mortar lines (reduces frost damage), no setback. Go to engineering bricks with their smooth glazed surface and printouts are fine. As you say, it's the corner/door/window treatments that bring it to life.
Yes, I think the proper windows and doors are the important thing.
J
Two good guards (one for the GW toad and another in anticipation of the upcoming Dapol 20T BR brake), a diesel driver for the Class 08 and two steam loco crews.
I'm pretty useless at faces so tried the impressionistic approach with black wash.
I mostly use acrylic, but I did mix up a batch of flesh as recommended in an article in MRJ 230. You need enamel paint and mix of white, red, yellow and blue. The paint layer needs to be thin so as not to fill the fine facial features.
I must contact ModelU, as I need a pilot bust for my 1/4 scale Piper Pawnee-25.
I need to really seriously think about getting the main layout planned and to do that I need to get a sense of the building footprints. I could do foam core mockups but where's the fun in that.
I bought a couple of LCut kits (LCUT) some while ago and thought I'd have a go at building the Signal Box (the other is a single road shed). There are a good selection in both 4mm and 7mm. The buildings seem to be generic and there's no indication in the description of the origins of the buildings.
LCut kits are laser cut card kits. The parts are very crisp and precise and fit is excellent. The price for an 0 gauge is very reasonable, about 1/3 of that for a laser cut ply kit. So, good value I think.
Here's what you get:
One of my first concern was the walls, the bricks to be precise. I really couldn't see how to do the mortar lines. I did try, honest, but I didn't like the result.
As I looked at things, a light went off, why not use Scalescenes to create a hybrid model. This I did by buying R010 Signal Box and TX01 Brick. One of my issues with Scalescenes is that windows must be laboriously cut, laser cut solves that problem. If you know what you are doing, you can buy building components.
Over the course of yesterday and today, I felt my way through the kit, using Pritt to stick paper brick on the card walls.
I also assembled and painted the windows and doors, as well as the steps. The roof was done using overlapping paper strips.
Here's where I am:
The corners are probably the ropiest part but don't look too bad. You really can't better John W's brick rendering and even in 7mm, I don't thick mortar lines have much depth.
The next phase will be to detail the interior. For that I have a moulded back wall from Invertrain:
The Scalescenes kit has some printed details that I can use. I'll create side walls using Evergreen sheet. I also have a set of levers.
Last edit: by Brossard
