Johns 7mm Coach Workbench
Each one has four 2 piece struts. A 10mm length of 0.45mm NS wire was soldered under a length of 0.032" brass wire. When all 80 (!) were done, 0.032" wire was soldered to them to form the luggage rack frames. There are enough for my 7 compt 3rd and 3 compt 3rd brake.
I did use jigs to get everything looking the same.
Next task is to make the netting. For that I have a frying pan fat catcher to cut up.
A kindred spirit. :lol:
Allan
Hope this helps. Anyone emulating this should get the strut spacing better than me. The rack on the left is from the back and you can just see the 2mm or so of 0.45mm NS that I left to insert into the partition. The rack on the right is from the front. Not easy to see but the struts hook upward.
I am most impressed.
Regards Rob
I'm not over the moon. The mesh on the luggage racks is somewhat ratty. The racks themselves were a devil to install in the partion and, in general it's not as crisp as I would like.
I shot off an email to Paul Bambrick at CPL (CPL PRODUCTS) inquiring about the interiors he talks about. If I can get some more credible parts I will redo this.
Amazing.
Allan
You're far too hard on yourself in setting such high standards, but I understand that we all want to achieve ever greater things.
A huge well done that man!
:thumbs
What I have is not dire and I'll leave it be until I see what CPL can offer.
Allan
You are setting the bar really high, especially if you plan to go back and make changes to what looks to me to be a superb job in the first place!
Regards Rob
1) I pre-drilled the partitions using a template that I also used for setting the strut spacing. When I went to fit the assembled racks, I found the holes weren't right and spent a lot of time agonising the holes in the partition to get everything in. Quite a mess.
I would solder the struts to a piece of brass strip and just glue it to the partition next time.
2) The other issue was in the choice of mesh material. The steel mesh I used is really too coarse and I couldn't clean it up because the CA won't tolerate filing.
I would look for some fine brass mesh next time. Perhaps this is in the CPL kit.
I'm waiting for confirmation of the kits.
Otherwise, I'm happy with everything else. I actually did a trial fit into the coach and it does all look quite good.
Your problems are part of the reason that I will make my first attempt in styrene. The second reason is that I plan to have a go at cutting my mesh from 10 thou styrene sheet with the Cameo.
Regards Rob
I like your thinking!Yes and part of my problem is that I have a good plan and am looking for a perfect one.
Regards Rob
Allan
I got my passengers:
Cast resin I think, all different poses. A bit dear. Now I have to research the in fashions for 1962.
Also, I received my JLTRT Mk 1 CCT kit:
The main parts are resin with bags containing lost wax and whitemetal bits.
The other coach kit in the queue is Slaters SR PLV/GUV:
Ends provided to do either the PLV or GUV. I sent off for a screw link coupling and springing unit.
I have in mind to make up a parcels train with these two vehicles plus the Gresley BG.
Last edit: by Brossard
