Johns 7mm Coach Workbench
The late John Ahearn's book, Miniature Building Construction, did help but it still took me a year to get me head round it where I realized that I needed a knife and not an axe to cut cardboard with and proper glue and not jam to stick it all together !
Allan.
You only get better by trying.
I suppose the same applies to RTR stock. I never left an item untouched so everything I had was unique in one way or another.
I added a lot of detail, just as I did for the first set, using the Kemilway instructions as a guide. Having gone OTT with the first bogies I really have no choice but to continue.
The Parkside thing turned out to be a bit of a bust. I did use the brake shoes but wasn't given enough black sprues with yokes for four bogies. I decided to make my own yokes from brass, which you can see in the bogie on the right. The hangers weren't suitable either so I made some from plastic strip.
The diamond shaped pull rod is 0.032" brass wire.
I also added safety loops from brass wire which can be seen on the right.
None of this can be seen at all clearly when the model is running but…..
I'm just working on the bolster springs.
I won't be going to that level of detail on those that I am just working on because what I am charging doesn't really warrant it and the gent that I am building them for would have been happy with the basic Kirk bogies.
That said I have a Quad art set on order from Ian so I suspect that I will be following in your footsteps when I get that far.
On the couple of sets (admittedly they were Fox not Gresley) of Kirk bogies that I have built so far I didn't have any issues with getting them running okay they are just a bit basic (as Ian freely admits). The addition of some steps from Styrene greatly enhances their looks.
Regards Rob
I'm very interested to see how you interpret all this.
On my first set, I initially made steps from brass strip. As I thought about it, I felt that the brass was too thin so I made some plastic strip (0.5mm) overlays to beef things up. I'll do the same with these.
I've built up the bolster area, note the pins on either side of the bolster on the left. The idea of these is to permit the bogie to rock fore and aft but constrain lateral movement. This should prevent coach rocking. The bogie on the right doesn't have these so it can rock in all directions. This constitutes a form of compensation.
Note the steps, made from brass strip with 0.020" wire soldered on and inserted into the bogie sides. I made them a more representative thickness by gluing on 0.020" (0.5mm) plastic strip.
I still have to add the boxes containing the bolster springs (cut down 4BA screws). These will be glued to the white pads under the center of the bogies.
Last edit: by Brossard
A fine example of what can be done to improve a basic offering.
Regards Rob
These are moulded resin from Invertrain. While browsing I found some very apt seat covering brocaide pattern. Probably not LNER but I think it looks appropriate.
I copied the pattern and made a Powerpoint file. By trial and error I reduced the size until the pattern looked to be about the right size.
Next I printed enough to do all 14 seats. I cut out and did a rough fit to the seats, folding as required to get the paper snug.
I used spray adhesive and stuck the paper down. Messy stuff but I got it done only having to re do one seat that went ahoo.
The bottoms, sides and tops were painted a bauxite colour. Any areas where there was incomplete bonding were stuck down with CA.
Finally a coat of matte varnish.
The kit comes with white plastic partitions that are not full height. I cut the ends off for the corridor. I then added plastic sheet to make the partition full height.
The partition decoration is a paper overlay. The original was made available by Mike Trice over on RMWeb:
Titivating Bachmann's Original Thompson LNER Coaches - Page 2 - Modifying & Detailing RTR stock - RMweb
See post #41 for the PDF.
I blew up the artwork to suit 0 gauge and, because we're in a larger scale, added real pictures. I also added a brown panel under the buff so that white didn't show at the top of the seats.
Getting paper to stick to plastic was a two step process. I started by laying down spray adhesive on a sheet of paper and laying the partitions on that. This was repeated for both sides and trimmed. I then cut out my printed partitions and used Pritt to stick them down.
Seats were attached using contact cement.
I think they pass muster but now wonder if I shouldn't make luggage racks as well. :hmm
Nice seats. With that amount of detail do you have a choice re luggage racks? Bit of chicken wire mesh, few pieces of brass rod and angle, 4 weeks later…Mind you, some of the early designs had very ornate brackets.
By coincidence a few weeks ago I made a start on drawing up ends for luggage racks for the all third but I haven't finished them yet.
I also thought about using the Cameo to cut circles or ovals of foil for the mirrors. I will let you know how I get on with that.
Last edit: by Rob Pulham
Regards Rob
First the 3rd:
I added the strip at the body to act as a recess for the roof. One of the problems I see with this is that the sides tend to bow in alarmingly. Putting the roof in the recess is one feature to hold the sides straight. Another idea I had was to use the partitions. I slipped one in to illustrate the point. I added a kind of hook to the corridor side to engage the top of the side.
This shows where I got with the roof. It is pretty much correctly shaped but does need to be held down somehow. I'm mulling over whether to make it removable using screws to secure it. I've ordered some passenger figures from Omen-Miniatures Omen Miniatures | Scale Figures for Modelling & Model Railways . They're a bit dear but do come highly recommended.
Here's the full brake body assembled. At least with this keeping the sides straight is a doddle.
The 3rd brake body is in WIP.
The seat and partition looks superb. I think that I may well follow your example for the all 3rd.
Regards Rob
That would be much appreciated.
Regards Rob
