Johns 7mm Coach Workbench
I don't think British 4mm scale will ever be right and 00 is with us to stay. Another reason to switch to 0 gauge, at least the track gauge is right (well almost, 7FS gauge of 31.5mm scales to 4'6").
One thing that struck me was the lack of auto-coupling gear. Is this supplied as something you have to add?
Underframe detail. They were pretty basic. Gas cylinder for the lights, vacuum cylinder, pipes and brake wires.
Peco had some weird and wonderful ideas back in the 70's, John, and especially when they commissioned me to build the master for a typical British station that Pola were to produce in HO !I had the Rivarossi Royal Scot and a rake of coaches. The best models on the subject I have ever seen but spoiled irreparably by the scale. I didn't know Peco was involved. I hope lessons have been learned.
Anyway, I built the damn thing, got well paid for it and that was that. No such station ever appeared on the market ! Crap master perhaps ?
And what would you like to know about Pecoscene, another product that I was asked to test, revealed it for what ir was - fire cement - again got well paid for it and a year later Peco had to take it off the market for, like fire cement, it crumbled and broke down after time if not treated the way I treat it and that's to colour it with Colron wood dye which no body seemed keen to do
Allan.
Don't know about auto coupling gear Nigel. There's nothing in the box. In the prototype autocouplers have to be able to connect the steam and vac hoses automatically, as well as the coupling. Russel doesn't mention in the book I got from you apart from the slip coupling. The book does have some good detail drawings so I might be able to infer the missing detail from that. Another job on the to do list.Hi John,
I guess it's one thing to makea one off model and quite another to productionise it. :hmm Glad you got paid for your efforts but it would be satisfying to see the results of ones work in the shops.[user=565]Brossard[/user] wrote:Peco had some weird and wonderful ideas back in the 70's, John, and especially when they commissioned me to build the master for a typical British station that Pola were to produce in HO !I had the Rivarossi Royal Scot and a rake of coaches. The best models on the subject I have ever seen but spoiled irreparably by the scale. I didn't know Peco was involved. I hope lessons have been learned.
Allan.
Trusses done:
Thanks to Rob for his great photos which were a great help.
Transverse trusses were kind of tricky and built mostly in situ.
I made a jig for the outer trusses:
Not foolproof so care must be taken to get everything symmetrical.
We're getting there I think. The next main job is to detail the underframe.
An important distinction for full brakes and half brakes is that there is a manual brake application system. I tried to represent that here.
The guard actuator is a screw crank which pulls on the rod that can be seen on the lower picture to the right at the middle of the coach. This is attached to double cranks which pull on the rods that actuate the bogie brakes.
This was quite a job with lots of "aaaarghhhs!" and do overs, but I think I got it.
Last edit: by Brossard
Less 'aaaarghhhs' you see !
Bril' workmanship as usual.
Allan
Edited to spell aaaarghhhs right.
Last edit: by allan downes
There's a correct spelling for "aaaarghhhs!"? :shock: Who knew?
Well at least with buildings there are no wheels or brakes to bother with.
Yes. F&$K.
Not sure, John, but by hitting any finger with a big hammer somehow gives the word a more positive meaning - noun, verb or otherwise..So is that a noun, verb or term of endearment? :oops:
Allan.
I used copper wire to connect the vacuum cylinders to the pipe.
Notice the steam pipe has a low point for the drip trap.
The dynamo has a faux belt from scrap brass.
A lot of fettling was need to clear fouls with the bogies.
Battery boxes next I think.
I think this completes the underframe detailing.
I will turn my attention to the coach body now. There are a few bits and bobs to see to.
I can see the light now.
Underneath:
I sprayed it with grey primer last night and put the black (Testors spray flat black) on this morning.
The Kirk dome ended roofs are an interesting challenge to get to fit nicely.
Regards Rob
End details made from plastic scraps and a bit of copper wire.
