Dapol Presflo Wagon Kits
Time on my hands?
Kevin, rolling stock weighthttp://amra.asn.au/wp-content/uploads/sites/7/2016/03/massstandard.pdf
One ounce plus 0.5 ounces per inch length. Or 28g plus 14 g per 25.4mm. Metal wheelsets add a bit more.
That's for HO 1:87, and S 1:64. So good for OO.
Could be when I was playing around with my shunting puzzle plank and trying out Kadees.
If you compare plastic wheels with metal ones the metal ones mass more. one of the reasons they run better.The NMRA guidelines are in my opinion a bit light.
Mass is just the amount of matter a body has. Two wheels, one of plastic (mostly carbon) one of metal (usually a metal alloy) of the same dimensions will not weigh the same. Carbon (atom) has a lower mass than copper or iron (atom). That is why lead or more commonly now steel is used as weights. You would need almost 20 times more plastic than lead if you went by volume. Probably more as there is a lot of empty space in plastic polymers. Should probably be comparing pure graphite rather than plastic.
Posted: Thu Aug 15th, 2019 03:28 pm
The usual things - height gauge, the coupler, plastic shims (make your own or KD), glue and screw to go through the gear box hole. If you use NEM KDs you will need the mounting blocks from Parkside/Peco and some boxes from Bachmann NEM tension lock couplers.
I usually use KD screws and whisker couplers.
NIgel
____________________
Hope this helps and I trust you have a height gauge,
The post Nigel had written was specifically in response to your request with kits, so I hope it is of help to you.
