Dapol Presflo Wagon Kits
Time on my hands?
Hi Nigel. Thank you for your reply. Two types, which is most useful, or do they do different jobs?Best wishes Kevin
https://www.humbrol.com/uk-en/decalfix-125ml-bottle.html
It looks like I will have to do my own experiments and trial runs, as I haven’t got any confidence that the plastic will support Kadees, and will have to check out the NEM pockets as recommended by Jeff (SR Man) from Parkside and then fit the, droopy Kadees and prop them up. There is a note about some parts maybe out of shape, remedy place in bowl of warm water and bend to shape? Sounds a bit dodgy to me. The Magnets came from York Magnets today and I realised that although they are excellent for holding “square flat parts together “ they do not work so well with the Presflo Wagon Kits as they are neither square nor flat. Best wishes Kevin
It was known many years ago that some plastic kits needed some warmth to get them back into shape.
The Parkside kit is the mounting block, not the NEM pocket. Unless this has changed since I last bought them.This provides a triangular mortise into which the tenon-NEM pocket found on Bachmann NEM tension lock couplers is attached. You will need the mounting block and Bachmann NEM couplers, the tension lock part gets binned.
Makes this method expensive and wasteful. Adjusting the height is a pain as well, as usually some of the mounting block height has to be taken off, and the blocks have to be glued on, no mounting ho!es. This is a weak point. See my post of several years ago on how to do this.
I have gone back to using regular gear boxes and whisker couplers, which can be glued and screwed using self-tapping screws or a regular screw going into an undersized drilled hole.
Kadee will even do most of the work for you for a bit more. Set #3 is 4 assembled #148 medium length, center set whisker couplers mounted in gear boxes. Shim to height, glue and screw, or shim to height and screw. Gaugemaster has these, £7.00, enough for 2 wagons.
One of the issues with most plastic freight kits is the design has not been updated to accommodate coupler changes. Some of the Dapol masters date back to Airfix days.
Caveat emptor.
Edit. I just checked, the post was 6 years ago.
The price difference between a RTR Presflo and the kit is only about £4.00. And the RTR from their pictures comes with Dapol pockets (their version of the NEM 362). Which with a sliver of styrene as a shim and minimal fettling will accept Kadee NEM couplers without the droop. I am not sure what the kit comes with. Probably depends on the vintage.
If you add in the time this takes you are probably better off buying the RTR version. It can get tedious and frustrating retro-fitting Kadees when a model wasn't designed for it and/or the manufacturer does not use NEM standards.
Best wishes Kevin
Afterwards when the plastic has hardened after gluing together. Leave it a few days. Never tried doing it wheels first with a plastic kit. Good point though. I have attached one side and then worked out where the other one goes using the wheel set when building to EM gauge.
I have done it wheels first with white metal kits. Not so flexible as plastic. Easier to use split axles and a sleeve.
Wheels out when painting. Cover the bearings on the inside with a small square of masking tape.
