Soldering on Model Railways Part 1
(In Topic #12972)
Draper ( and silverline) are relabellers of cheap tools, however if you need a cheap tool that you've seen from them then have a good look around the net and you'll probably find the base tool cheeper elsewhere.
The soldering shown would have my old workshop practices instructor having kittens, however it is passable if not best practice.
Odd things,
Not trimming the wire to just the amount bare required,
Cutting track webs opposite each other allows the sleepers to move in relation to each other.
Not showing adjustment of the wire stripper to correctly strip the wire.
Last edit: by The Q
Please be exceeding cautious when working with chemicals. Read the label and take recommended precautions.
Fluxes for soldering can be particularly harmful to your lungs and may cause mild to severe reactions, possibly harmful long term.
Lead-free is almost as nasty as lead-containing solder. All soldering needs to be done with good ventilation moving away from the work station. And wearing gloves and eye protection. Most fluxes, liquid or solid, are usually highly corrosive, again, gloves and eye protection. Even the organic flux I use has to be used with caution.
You very clearly show that the basics are not difficult (whether we do exactly the same as you is not the point), but I think this clip would really benefit from some clear up-front pointers on the health and safety basics of working with solder and flux. Many of which are in various posts right here on this site.
