Fitting Grab Irons Pt 3
By Ray Turner
I hate installing grabirons but I love how they look. I would say that the method of using a soldering iron to heat a grabiron and pushing it in has a several drawbacks:
1. It is possible to damage a nice car with a misplaced red hot grab iron
2. Some grabiron material won't like being heated (soft brass etc) and is not strong enough to press fit in this manner
3. It will take me longer than to drill the car with a pin vise
4. You must use wire grabs (some much for P2K, Intermountain, Red Caboose etc.)
5. Won't work on wood cars
Not too long ago, I made similar suggestions to the old time train guys I know. They laughed and said "Nobody likes drilling grabs, get used to it" I have learned to take the time to drill. It took a while to accept that it will take time to do it, but I find it to be worth it. As you get better at it, it goes quicker.
Green tinted Carriage Windows – a basically good idea with a down side and a correction
By Mark Nethery
The latest copy of the NRMA (The Auto Club in NSW, not the National Model Railroaders Assn ) “Open Road†came in the post and the protective plastic envelope has a nice green tinge to it.
I thought it may be just the thing to use behind the glazing in a/con cars to give the green tinge - where it is wanted and I thought I could be using this plastic in one of my NSW Railways passenger car sets!
From Alan McKenna
There is a strong risk that the magazine wrapper will disintegrate after a matter of weeks or months, depending on light exposure. The mail handling companies tend to use environmental self-degrading plastics.
Browse through the stationery departments and look for something in rigid plastic (e.g. polystyrene) with the sort of colour you need.
From Ben Noakes
You could also use the plastic that is used in document wallets for different tonings of windows which would be a lot more workable being stiffer.
Covering Return Loops
By Several Modellers
Most people like to hide their reverse loops. Actually they are a good place for an industry or two with a couple of spurs inside. A raised urban scene which covers part of the loop works very nicely.
If you hide it in a tunnel you can put an industry, town, mine, etc. on top of the elevation.
A freight yard and turntable are big space users but give you staging and a focal point
Use the space as an Access hole.
Cutting PVC Pipe
Check out a PVC pipe cutter at your local hardware store. They are about 10 16 bucks and is quick, accurate and no mess – John Warren
I use the pipe cutter to mark and start a square cut. Then I use my razor saw to finish the cutting. It leaves a good smooth end that rarely needs and dressing up with a file or paper. As posted in a thread above, using the tubing cutter by itself distorts the tubing. A fresh blade in the cutter will help, but it is still not as true as using the razor saw - Greg Cornish
Closng Freight car and Wagon doors
Some brands of freight cars have a tendency for the doors to open mid transit over any length of time. A very tiny dab of white glue or varnish in the door track should stop the movement. Alternatively a small strip wedging the door track will stop the movement.
Masking a Model for Painting Pt 1
by Peter Rhodes
Masking tape is not always the answer for masking things off… I have personally had to cut poster board or copy paper to the desired design, then tape on to it, use clamps, clothes pins, etc to keep it in place long enough to get the job done without marring the paint under it.
Masking a Model for Painting Pt 2…
by Gary Collins
The best general masking tape I have found isn't really masking tape. I use Scotch 230 Drafting Tape. It can still be found in some office supply stores. I get mine from Office Max. It has a lower "tack", and will not lift paint.
Using Ground Foam
by Glen Thomas
On my previous layouts, I glued everything down including ground foam. On my current layout, I accidentally tried something new for me at least.
I was sprinkling some ground foam on the layout when I accidentally got it in an area I did not want it. I assumed I could just give it a quick brush with my fingers to clear it away. I soon found that it held on a lot better than I thought and I had to get the vacuum to pick it up. I realized then that I might be able to re-put it where I wanted it and press it down lightly to fix it in place. I tried it and was surprised at how well it worked. It stays in place very well and looks natural. Just do not compress it down too hard or you will tend to flatten it out too much. The best thing is that if you decide you don't like the look or if you want to change it at some time later on, you can vacuum it up. I was concerned at first about not being able to clean up dust, but this really has not been a problem. I cannot say that I would recommend this for areas at the front edge of the layout or too close to track, but for all other areas it works well. You can try a small area for yourself. If you decide the technique is not for you, just grab the vacuum.
Substitute Materials for flat car loads
by Dean Olds
Plastic drinking straws make pipe loads for flat cars. Small sticks from real trees can make log loads for pulpwood cars. Small diameter PVC pipe can be used for culvert pipes for loads or scenery. Thin Card can be used for slab steel as can pasta sheets suitability cooked and varnished. Old watch parts can be used as scrap as can shredded foils.
Ooh! Look! The end's fallen off!
Colour In The Real World
http://yourmodelrailway.net/view_forum.php?id=175
Buildings For Slitheroe
http://yourmodelrailway.net/view_topic.php?id=10981&forum_id=14
Replacing a Damaged Ballasted Point
by Jeff Reitman
Assuming you used a water based glue to set the ballast, lay a paper towel over the point set and SOAK it with water.. Keep it wet and eventually, the ballast will soften enough to lift the point. The paper towel will keep the water localized. Of course, the whole mess may just pop up with a little coaxing as well.
Weathering Animals
by Mark Pierce
Range stock should not be shiny. At the very least, they should get a thin wash of India ink and perhaps some mud around the hoofs or maybe even to their bellies. Even these pampered milk cows are not shiny.
Edging a Station Platform
by Charles Beasley
Yellow chart tape would make a good representation of the platform edge safety strip.
Cleaning Metal Castings
by Andy Reibel
To help paint adherence, soak white metal castings in white vinegar after you scrub them with warm water and detergent, rinse off the vinegar and allow to thoroughly dry.
Scenery Colours
by Jim McNicholl
If using Polyfilla, plaster of Paris or the like for a scenery base, colour the plaster/water mix first with powder paints. The white plaster will lighten your base colour, so dark brown will tone down to a mocha colour and dark grey to a much lighter shade. Once set, you can apply whatever paint wash you like, although don’t make your wash too thin otherwise most will absorbed into the plaster base. This also avoids the “white†showing through where the paint cannot reach.
Strengthening Plaster-impregnated Scenery
by Jim McNicholl
One old dodge used to make plaster of Paris stronger is to mix fine sawdust into the “splodge†before application. A dash of glycerine will also slow the setting process giving more time for moulding the mix to your contours.
River or Stream base
by Jim McNicholl
A cheap form of river or stream base is budgie grit from the pet shop. It looks very effective if you are using resin to represent water. The grit sticks quite nicely in PVA.
Suede paint to replace earth colours
by George Nixon
I have always had an aversion to organic materals on the layout. Every attempt I made ended up attracting critters of some sort, and that includes my own foray into peat moss. I suspect "plain dirt" alone would not cause problems, but I have never used it as the only organic on the layout, so I cannot be sure.
I have found an alternative I like better anyway: I go to the local HD type store and buy suede-texture paint. This is not some "sponging" or other artistic effect. It is just paint that dries to a suede-like texture. When colored the relevant shade of brown, it is darn-near perfect for 'earth' - just enough texture to it. You can enhance the texture by rolling a deep-nap roller across it after it gets tacky. I do that for more 'churned up" areas, and just paint it on 'as is' for more developed areas (e.g. pastures in the first case, a yard or industrial area in the second).
Making Concrete Abutments Pt 1
by Rob Spangler
I build concrete tunnel portals, abutments and piers from .040" styrene sheet. Modeling such items with styrene is fast, and the finished products are light in weight and dimensionally stable. Just because the prototypes are solid does not mean the models have to be.
Making Concrete Abutments Pt 2
by Mike Bonellier
I have had good results using both balsa and bass wood. I build the abutment, wall, sidewalk, whatever, out of wood,seal it then when it's dry I use a light coat of thin-set spackling compound. When it dries you can weather or age it with paint, chalks, india ink stain or anything else. You can crack it and remove pieces like old stucco.
