Getting your Ballast Colour Right
By Mel Perry
If you are modelling a particular section of prototype railway, one of the big indicators to the region is the colour of the ballast. You can easily check this feature using Google Maps from a close range although you may have to go lighter to account the relative darkness of your layout room to the great outdoors.
Treatment for Telegraph Poles Pt 1
By Several Modellers
In HO (or OO), I take a fine toothed saw (Zona for example) and rub it up and down the pole to give it a bit of grain texture. That might overdo it in N but perhaps if followed by a very light rub down with very fine grit emery cloth it could capture the same effect. (Dave Nelson)
For the modern era, I would leave them smooth and paint the poles an appropriate reddish brown. If you want to get rid of the shine of the poles before you start you could scrub them with very fine sand paper. In the modern era, the poles are not climbed but accessed by a cherry picking crane. (Noel Jamieson)
Treatment for Telegraph Poles Pt 2
I use a Metallic Green paint to simulate the older green coloured insulators (Wayne Toth)
I found a green, rather irredescant nail polish that really looks good for the older, green glass insulators. You could use a clear polish for the clear glass ones.(Richard Cowman)
Making a Mown Lawn
By Michael Liddicoat
To create a mown lawn effect with static grass, I create two rectangles of light and dark green grass. These can be set into glue on baking paper. When dry, cut into strips, peel off the baking paper and glue them down alternately to create classic stripes.
Filling in Frogs on Home Made Points
By Reg Britten
I found myself unable to get points that would suit my range of rolling stock which I had accumulated over a 50 year period. Peco were fine to a point but the older stock would ride high through the frogs or derail.
I made a number of points to fit my layout but with clear frogs so the old Hornby stock could travel through. As I gradually replaced the wheelsets with less coarse examples (but not necessarily fine scale) I was also needing to stop “wheel drop†so I made a series of styrene shims to fit into the frog space. As my wheels could have been made an even finer, there was plenty of room to add more shims (glued in of course) and keep control of the depth.
Checking Old Controllers
A number of modellers have obtained old power packs/transformers/ controllers (whatever your terminology extends to) but not necessarily able to check them. There are a few things that you can do.
- Check the condition of the cord. If there is mechanical damage or deterioration of the insulation, do not use until it is replaced
Use a cheap multimeter to check that there is no connection between the active or neutral pins and the earth pin.
Check that there is at least a small amount of resistance between the active and neutral pins. Because the transformer is an inductive device, there is more resistance when it is live because of the voltage load.
If the above are all OK, connect a 12 volt automotive globe of around 15 watts to the output. Turn the power on momentarily and see if the globe lights.
If it does light, turn on the power and vary your controller. This is called a dynamic test and will be the best test of your controller.
Bear in mind that older controllers will not be able to handle the lower power draw motors we are fortunate enough to have today but these controllers can always be used for lighting and other auxiliary supplies.
Protecting Layouts from Dust
By Kenneth Coghlan
I have a standard plank layout in a relatively dusty area so I find it easy to take a plastic garbage bag, split it so that it is double length and use it until it develops holes or similar tears. A bag done this way lasts quite a long time , is easy to put to one side out of sight when I run trains or work on the layout and quite cheap and definitely easier than dusting!
A note from Doug Dickson
I have tried this, but plastic bag material can mould itself around sharp objects, so unless extraordinary care is taken to lift it off vertically, it can snap signal posts, chimbleys, etc., very easily. Far better in my opinion is sheets of tissue paper of the sort used by dressmakers etc to fold up clothing.
Allowing Space when planning Layouts on paper
By Craig Brantley
Everything works on paper. Do not be afraid to modify your plan when you start construction. If you are lucky enough to have an entire room, pretend your room is smaller. When drawing your plan, reduce the layout area 6-8" for up to 20' rooms and below and 12-18" for rooms above 20'. This will allow some room for planning mistakes.
Planning Layouts on paper for maximum enjoyment/minimum trouble
By Craig Brantley
Minimize your gradients. You should be double heading your trains because you like it, not because you have to.
Provide the ability to continuous running or at least a way to turn around. Point-to-point is great for operating but when you want to just turn on the trains and watch them run it is a pain.
Use the largest radius you can fit in.
Make areas where cars are uncoupled as level and as possible.
Weights for Holding Cork and Track
I have made weights for holding track or cork down when gluing by filling empty tin cans with cement. Once it is set it gives a great weight. You can make as many as you need, they can be stacked for extra weight or laid on their side to keep track down. They also easily stack away when not in use.
Models of Stationary Boilers
By James Bradshaw
I have found that the shape of those plastic party poppers are ideal for making stationary boilers, particularly on my logging layout where I have two end points. They also make great under the tarp loads either vertically or on their sides giving a bit of a cryptic shape.
Downspouts and Piping
By David Russell
For downspouts and piping in general look for florists wire. It is a very soft wire used by florists to bind bouquets. It is usually painted green and comes in many gauge thicknesses.
Cheap Lumber Sources
By George O’Hagan
Wooden coffee stirrers and ice cream sticks are an inexpensive or free way to get some scale lumber. They make good planks for loading docks, roof rafters or timber loads. They are easy to cut, and take stain well. For weathered timber stored or used outside, I use a HB or 2B pencil and colour the timber to an appropriate grey tone.
I like to model the interiors of buildings as much as possible. To model a wooden floor in a building, I glue coffee stirrers to a thin piece of card, cut to size. These are then trimmed to the card and a line scribed the length of the stirrer to create a more accurate scale width. Horizontal lines create the individual boards. You can add nail holes with a pin. I finish off with a wood stain and a coat of beeswax polish. They look great through an open door or large windows.
Simulating Rich Soil
By Harry Parker
To simulate rich soil, I use coffee grounds obtained for nix from the local barista! I mainly use grounds in my garden for snail control and noticed that it looked like rich farm land. So I aired off a cup full of it spread to lose the coffee odour for a couple of weeks, sifted it and glued it in place. I now have some of the lushest soil in modelling!
Making a Level Crossing on a curve Part 1
By Wayne Toth
A few suppliers offer laser-cut wooden crossings, but I made my own by using strip styrene. Since the crossing is on a fairly wide curve, I simply bent the strips to (unprototypically) match the curve.
If your road is paved, you could do the crossing using sheet styrene, cut to fit the curve.
For sheet styrene crossings on curves or street trackage, lay a piece of paper over the area where you want to place the crossing, then rub a pencil, held almost parallel to the paper, along each edge of each rail, taking care to ensure that the paper doesn't move. Mark lines on each of the lines thus created to denote the end points of the crossing's width.
You can then cut out the portion of the paper between the two outermost curved lines, using it as a pattern to trace the edges of the approach portions of roadway outside of the rails.
Making a Level Crossing on a curve Part 2
By Wayne Toth
To create the part between the rails, cut the pattern so that only the two innermost lines are left, then trace that shape onto the sheet styrene. Use an X-Acto or a utility knife to cut out that shape, then carefully sand both edges to smooth the cut.
Next, set a drawing divider or compass to a width suitable for flangeways, and move the divider or compass along both edges of the curved piece intended to fit between the rails. Use a knife, or file, or sandpaper, to remove the outer edges down to the lines thus created.
On the "paved" crossing and street trackage, I let the oversize plastic "spikeheads" on the Atlas flextrack and turnouts determine the setting of the dividers to create allowance for wheel flanges.
Ballast for Yards
By Scott Chatfield
Many yards in the steam era were covered in cinders. Cinders were free. What had not fallen from the smoke plumes of the steamers was taken from the ash pits and spread on and between the tracks. Its slightly oily nature help keep weeds down and was easy to walk on. This was also a safety issue as mainline ballast is not easy to walk over safely and quickly by yard crews
Diesels did not make cinders, but most yards in the '70s were still mostly cinders, although tracks that had been moved or upgraded might have stone ballast. Limestone prefered because it was easier for the switchmen to walk on. And the level of the ballast should be just below the tops of the ties and fairly level between the tracks.
The problem with cinders in N scale is they would practically be a powder. Dusty areas will be colored by the prevailing dust color, so even a cinder-covered yard will take on that color. In a less dusty area, like the northeastern US or most of the UK, the cinders will stay blacker longer.
Hints & Tips No. 2148
Using LED Strips
Many LED light strips allow you to cut them at 3 LED intervals. It is easy to solder two wires to these and they can then be used to light up buildings. I power them through an old DC controller so that they can be dimmed to an appropriate level. For an older style of light I have found a covering of masking tape gives a nice warm effect.
Removing Dust from Rollingstock
By Jason Shron
Every layout room generates dust, and as it settles on our model trains it becomes very noticeable - especially when we take photos of our models (as most of us like to do).
Next time you are at a pharmacy, head to the cosmetics aisle and pick up a blush brush. The bristles on these makeup brushes are so fine that they easily remove the dust from grab irons, firecracker antennae, stirrup steps, and other fragile details without causing any damage. It is NOT recommended that you borrow your wife's brush for this purpose…
