Buildings as Low Relief
By Raymond Stewart (GA, USA)
I have colored a building I found on the Internet using MS Paint and gave to a friend as a backdrop building. It works fine. However you will need to place it on thick plastic or foam core board to keep it flat.
Hints & Tips No.333
Underground "Utilities"
By Tom Decker (Michigan)
Since I am building my layout on flush doors, I run wires for structure lighting and track power through the styrofoam scenery base. Just grind or file teeth on the end of a piece of 3/8"(10mm) tubing and chuck it in your electric drill. Bore through the styrofoam as needed, remove the tube to clear debris, then reinsert it and the wires will push through it easily. Pull it back out, leaving the wires in the hole.
Early Steam Engine Repairs.
By Trevor Gibbs
Early die-cast and plastic steam locomotives are usually fairly “bomb proof” but can develop a bit of a gait in their movement. Make sure that both the worm and the gear are clean of burrs which may stop the motor from doing its stuff. The other concern is binding valve gear.
Gently remove your valve gear and using a “larger-diameter-than-the-hole” twist drill, twist it with your fingers to de-burr your valve gear slot where the side rods are screwed to the wheels… and do not over do it!
Hints & Tips No.335
Locomotive Tuning
By Ted Allan
I recondition my locomotive motor armatures by carefully dismantling my motors, putting my armatures in a lathe. Before I had the Lathe, I used to use a power drill held in a vice. While it is spinning use some Aluminium Oxide paper to true and smooth the commutator.
I then clean out the slots using a pin, making sure than I can see the mica insulation and that there is no copper residue. I then reassemble and lubricate the motor sparingly. The result in smoother running is worth the effort.
Making Diamond Tread in Brass or Styrene
By Graham Ross
By using an old file and a heavy vice, you can tighten the vice with the file and soft brass or styrene to make diamond tread pattern for scratch building. This is very hard on files so use old ones for this.
Hints & Tips No.337
Nail Polish as Insulation
By Harold Shelton.
You can use Nail polish as an insulator between wires. If you create bare wires close to each other, simply paint it on. It dries hard and will burn with high currents and voltages but is very durable for model wiring purposes.
By Harold Shelton.
Hints & Tips No.338
Extending File Life
By Graham Ross
You can improve the life of your files by regular cleaning. Either use a cheap bronze wire brush as a file card or use some sharp edges to pick out the swarf in the file. It is also a good idea to run some chalk over your file which will help stop fragments building in your files teeth.
Building from a Scale Drawing
By Trevor Gibbs
If you want to use a paper plan for a scratchbuilding project, overlay it with a piece of waxed lunch wrap. That way, the drawing is protected from glue and you can constantly check your work.
Hints & Tips No.340
A Newer Way of Mounting Containers?
By Ian Cant
If you are modelling containers either old or new versions, try using steel weights under the floor of your flat cars. Inside your containers, use a fairly strong magnet such as a rare earth magnet from an electronics store.
Your containers can then be removed and no unsightly single edged tape, glue or anything else, and your wagons or freight cars will have more weight for better tracking.
Making Neon Signs
By Graham Ross
Fairly effective Neon Signs can be made by shaping wire to you required shape then painting your wire with luminous paint. The light about your building should give enough of a glow to light these in the dark.
Hints & Tips No.342
Using a Digital Watch.
By Robert Ferus (New Jersey, USA)
In N scale given the size a clock tower would take and how small watches are not at the moment, consider using a digital watch for a bank sign.
I have been dragging my feet a bit with posting Hints and Tips due to a couple of personal issues (wife receiving treatment but caught early and other duties as well) but also in part because the hints to the end of 499 went AWOL. Happily, I found them, today in fact after the file I thought was accidentally destroyed on a Portable hard drive that died was also on one of my cloud drives! So at the current rate we should have input for about 18 months. Hope that does not worry you all too much and I have had a pretty good innings seeing I started helping Brian MacDermott (who started the Model Rail Express hints and tips column15 years ago!!!
I will still post two a week rather than every three days as I was … that would keep me a bit more in sync than what I was before!
Hang Your Controller
By Loren Hall (Washington State, USA)
Tired of your dcc controller laying on your scenery? I attached a 3M Command hook to the back of my Powercab, screwed a eye hook into the fascia board, now I can hang the controller instead of laying it on the table.
Hints & Tips No.344
Planting “Cabbages” and other vegetation in OO.
By Graham Ross
You can represent Cabbages by “planting” whole cloves from your spice containers and painting them green in OO scale.
Corn fields can be made using green toothpicks slicing down the sides to form the leaves then painting some bright yellow on top. This takes a bit of work but would look very effective.
Hints & Tips No.345
Planting “Cabbages” and other vegetation in N scale
By Mick Lovell and Graeme Goodsell (NSW N scale Group)
We made rows of Cabbages and Lettuce for the N scale “Illabo” exhibition layout here in Australia with dyed sawdust rolled into a ball. A vine growing over a back fence was made by painting a trace of PVA glue and sprinkling with fine ground foam.
We made ferns in hanging baskets from asparagus fern glued into a painted bead of glue and hung by fine wire.
Hints & Tips No.346
Climbing your Telegraph Poles
By Trevor Gibbs (Melbourne, Australia)
Using the ordinary paper staples, you can make maintenance climbing stirrups by drilling a staple into the pole then cutting it off with side cutting pliers. Thin but fairly durable.
Bottles and Other Details
For the “Illabo” N scale layout we created model drink bottles by heating and drawing out fishing line to make a bottle neck. A washing line has some shapes cut from white paper, dampened, crumpled and spread on a fine wire line… and if these can be done in N scale..
Hints & Tips No.348
Answering Questions… at home or at an Exhibition
By Roger Joel
How many exhibition layouts have we seen where the sullen operators skulk behind the layouts appearing to openly defy anyone daring to ask a question.
Yes it can get a little tiring answering the question 'How did you make the rocks on the layout', for the umpteenth time in a day, however I reiterate the idea of encouraging the future members of the hobby. A friendly response also helps to create a positive attitude at the exhibition and so hopefully encourages visitors to return another year. When exhibiting we always try to have at least one group member available behind the layout to answer questions.
Hints & Tips No.348 Answering Questions… at home or at an Exhibition By Roger Joel (Alton MRC How many exhibition layouts have we seen where the sullen operators skulk behind the layouts appearing to openly defy anyone daring to ask a question. Yes it can get a little tiring answering the question 'How did you make the rocks on the layout', for the umpteenth time in a day, however I reiterate the idea of encouraging the future members of the hobby. A friendly response also helps to create a positive attitude at the exhibition and so hopefully encourages visitors to return another year. When exhibiting we always try to have at least one group member available behind the layout to answer questions. Hints & Tips No.349 Painting - Drying and Handling By Steve Cook (Alton MRC) It is essential to care for your brushes in order to get the best results every time. For oil based paints
Communicating Your Layout
By Roger Joel, (Alton MRC)
Most layout builders establish a location and historical period for their layouts. Having done so they then fail to communicate this to the spectator or at best make a passing effort by pinning a scrappy piece of paper to any convenient part of the layout. The thought that you put into the study and accomplishment of the period and location deserves much better than that.
Anyone familiar with the Pine Bluffs exhibition layout will remember that we have adopted a fictitious newspaper for the period and fitted extracts to the front of the baseboards as do a number of exhibitors. These extracts are mounted in sloping panels which are positioned so as to be close to the item/mini scene to which they are referring. Of course it is not necessary for all exhibitors to go to these lengths, just make sure the information is well presented and visible is enough.
Hints & Tips No.359
Painting - Applying Transfers and Decals
Pressfix or Methfix transfers, once applied, should be over coated with varnish to fix them permanently in place and prevent damage when the model is handled.
If the model has waterslide transfers, it is best to lay them on a glossy surface to minimise the visibility of the carrier film. To do this either paint the whole model or just the transfer area with gloss apply the transfer (decal) and finish with a satin or matt varnish to fix them in place.
Hints & Tips No.361
Painting Pt 8 - Applying Transfers and Decals
Cassette Alignment
By Bob Hughes Crewe MR&ES
Solder a short length of paperclip on the outside of each rail at the end of the cassette. These clips will then engage to fixed track at the end of the layout providing both positive alignment and electrical connection. On a micro layout with short trains they don't need fastening down to stop them moving.
I have done this on the San Vince de Rey which is N scale but they will work with any track gauge or scale.
Hints & Tips No.363
Contoured Hillsides
By John Rutter - (Wirral & North Wales MRC )On Corwen East we used a technique of re-using old cardboard tubes - kitchen rolls are particularly good, to form a lightweight substructure for "tall" scenery.
- The tubes were roughly assembled into the area to be filled and a rough contour marked on them.
- The tubes were then cut to the required length and angle and glued in place vertically with hot melt glue. We found that there only needs to be a run of glue where the tubes touch.
- Final trimming to contour was done with scissors.
- We used a rigid foam base, however, the fully glued tubes will, more than likely, be self supporting once set.
- The ends of the tubes were filled with scrap paper a to prevent leakage nd the whole covered in plaster bandage. It may be lighter to use PVA/kitchen roll. We found that the plaster layers became heavier than we would have liked.
Staples as Lampholders
Several Modellers
Staples can be cut in half without being stapled and filed: these are then usable as lamp holders on locomotives, coaches and brake vans. You could create simple lamps from plastic sprue, even turning them with a power drill and using a basic file.
Hints & Tips No.365
Blue Tack
Several Modellers
We have found "Blu-tack" useful for making N gauge wagons and coaches heavier, as it has a high density and can be compressed into a small space. It is also useful for OO wagons.
Representing Bigger buildings
By David Millard (Northamptonshire)
You could always model a stadium or other large buildings in low relief or as a back scene ie just give the impression of the railway going by the stadium. This will save space.
Hints & Tips No.367
Quick mountains
By Adrian Hall (West Midlands)
Ever wanted light but quick scenery? Then my tip is to use the expanding foam in a can. Quick and easy to use spray it in the area you wish to have any cliffs or mountains etc and it will expand up to something like 40 times it's original size to fill the area chosen. Very easy to carve with a bread knife and no messy polystyrene to cling to everything and clean up. Be very careful how much you use though as it does expand to cover everything in its path. Track, other scenery, everything.
A Note from Trevor - I have seen this material used but by many reports it can be among other things difficult to apply and control. Also it is not cheap! However to each their own and Adrian's method may work well for you!
Hiding the Backdrop Entry/Exit
By John Rumming (WA)
Have you got an entry or exit with a hole in it? If so, hide it from view with a building or a group of trees. This will mean the train will disappear behind into the back of the scenery.
Hints & Tips No.369
Removable building bases
By James Fenton
You can easily mount buildings on the layout to make them removable. Go to your local Dollar store and buy a packet of household sponges. Cut a sponge to be a tight fit inside building. Glue the sponge to layout, fit building over it.
By James Fenton
Hints & Tips No.371
Printing White on Black using one of the major Word Processors
From the Victorian Model Railway Society
You do not have to use a graphics program to produce white text on a black background or many other combinations of text and background colour for that matter. This explanation from a club member shows you how.
1. Type the required text setting font (typeface and size).
2. Indicate the paragraph to be treated. Select Format, and in Format click Borders and Shading.
3. Then go to Font in Borders and Shading, and expand the character spacing by 0.5 point; then select white as font colour.
4. Choose grey shading, applied to paragraph.
5. Click cursor to verify these choices.
Now you can make signs for your layout to your hearts content.
Modelling Brick Walls Pt 1
By Rob Pearce
Almost any railway scene is going to contain at least one building with brick walls. Brick walls are not the easiest things to model realistically.
Many modellers include card models for buildings, and these generally have the brick walls printed fairly well, but without any surface texture. Kits of buildings with brick walls have an appropriate surface moulded in, and for scratch building there is embossed plastikard available.
These surfaces provide the contours for brick and mortar, but they are of a plain, semi gloss colour which looks entirely wrong. Our aim is to achieve a realistic brick wall appearance, including variations in brick colour and mortar lines. The method I have used is fairly simple, but rather time consuming.
Establish an approximate colour. If using "brick red" coloured plastic this is not entirely necessary, but from a grey plastic base I apply a good coat of brick red enamel with an airbrush. Onto this surface I next apply the colour variation of the bricks. To get an idea of this it is worth while photographing some representative brick walls. These should be of the correct era for what you are modelling.
Now comes the laborious part. Using a fine brush, I paint individual bricks at random in a variety of colours. These can range from white through to black, and include various shades of brown. At this stage what I am doing looks entirely wrong - the colours are far too bold. But that is exactly the point. Any paint applied this way will appear strong and bold, which is not the effect required.
When the wall has reached the point of appearing to be suffering a severe skin complaint, the next step is to soften this down to a more appropriate level. This is actually very easily achieved by spraying on a thin, and hence translucent, coat of brick red enamel. This has to be done with an airbrush to get the thickness right.
Hints & Tips No.373
Modelling a Dry Stone Wall
By Andrew Cockburn
Cut strips of card board to the height, shape and contour you want your stone wall to be. Coat with PVA glue on both sides (unless the stone wall is part of the back scene) and hang up to dry overnight with weights to keep it straight.
Next day coat with suitably coloured Woodland Scenics ballast or small stone from your friendly local pet fish supplier and cover your card with the stone, glue in with PVA, allow to dry and place on your layout.
