cricut
#287788 (In Topic #21654)
have you ot one
Hello,
I think i asked this question a few years ago. Just starting to use mine again after it has sat on the top of the wardrobe for 2 years.
Hello,
I am going to need a sharp slender knife to clean up some of the corners i asume a swan and morton but which blade would be the best, as there are many different types.
Thanks in advance
GreenBR
I'm still using my Zing Air, bought in 2013,  cuts card and plasticard, for thicker card it requires more than 1 pass which can be set from the software, said software is a doddle to use.
Hello,
What is the software called that you use?
GreenBR
Hello,
I must admit that the bigest gripe with the cricit is that it will not cut PDFs produced on A4 size paper. This means that you need to be able to take the PDf apart as the Cricut cut and print is no were near A 4 in size. As no one apears to be using one on this site i can not get any futher insight into how other people are geting around this problem.
GreenBR
GreenBR said
Hello,
GreenBR
It's called Make the cut.
https://make-the-cut.software.informer.com/4.6
#287994
You may notice the name of the signal box as i expect most of my work to be wrong i dont  think it will be out of place.
My first 2 items made with the help of the cricut maker, not brilliant but not bad for a first try. I must admit it is more complicated than i expected.
Regards GreenBR
