Eradication of house moth?
(In Topic #13402)
Buying a fly swat in winter?
Hi All. The Battery powered Fly Swat.. I did have a couple of these one for use upstairs, and the only too common “ brown moth “, in my home at least, appears every winter/spring. A pound shop item usually readily available? But not in the winter. I converted one to a “ static grass applicator “ then when the moths seemed to be absent I experimented with the upstairs one, but, too much power ( 9 volt battery) and it didn’t work anymore. Now everytime I go to get a new fly shatter I hear the same reply “ No. we only sell them in the summer “. Can anyone please advise me? where can I purchase one now??? Best wishes Kevin
Battery power level. . . . At the top right of the screen you should see a plain white battery symbol, when you plug it in you should see it change to a white battery with a lightning symbol on it and a line moving up the battery to show its charging . . . No change in symbol no chargy. . . Check the idiot mode. . . You DID switch it on at the socket ;-)
Double check the cable is plugged in tight and even wiggle it a bit to see if your battery symbol changes
HTH
