Hornby VDA Van Conversion
(In Topic #6073)
So this Van will be converted with bogies & Kadee couplings ( it will slot in the time scale between Station Building construction, etc)
![](https://yourmodelrailway.net/gallery/95/95_110431_440000000.jpg)
The bogies are Steam Era H0 units,similar to a couple of others I have done.
Back later with more updates.
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/394.jpg)
New bogie mounting bolsters & centre sills.
![](https://yourmodelrailway.net/gallery/95/95_121755_370000000.jpg)
The piece of white styrene at the left will be the mounting base for Kadee couplers.
More to come.
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/2.jpg)
![](https://yourmodelrailway.net/gallery/95/95_122233_150000001.jpg)
This was still too low by about 1/16th of an inch.
Buffer beam as below
![](https://yourmodelrailway.net/gallery/95/95_122233_150000000.jpg)
was milled out with a dremel to look like this
![](https://yourmodelrailway.net/gallery/95/95_122233_150000002.jpg)
![](https://yourmodelrailway.net/gallery/95/95_122233_150000003.jpg)
Now when the Kadee as above #27 is fitted, all perfect. If buffers are retained, use a long shanked version like #21, etc .
Still more to come.
Are the wheels smaller on the new bogies?
Also, I presume all the white underfloor stuff is your own chassis addition to carry the bogies. :roll:
Any idea what make the bogies are Sol ? Steam Era Peter http://home.waterfront.net.au/~sem/bogies.htm They look handy. :thumbs
Also, I presume all the white underfloor stuff is your own chassis addition to carry the bogies. :roll: Yes
Now all finished , painted & matt varnished with new larger numbers to aid in operating.
![](https://yourmodelrailway.net/gallery/95/95_132059_490000000.jpg)
![](https://yourmodelrailway.net/gallery/95/95_132100_080000000.jpg)
Just putting the bogies on, makes it run better.
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/446.jpg)
http://www.mremag.com/news/091013/Hornby%20VDA%20Balfour%20Beatty.htm
