Hornby Terrier
Hornby idea of removing the weight from the boiler
Sorry Nigel for jumping the gun, Kevin is in expert hands. I had just hoped he was aware of the relevant photos in the Hornby guide, which I understand he had previously read.Best,
How you fix the decoder depends largely on how big and whether it already has an insulating cover.
I use Digitrax base decoders as testers, they come already wrapped. Are you contemplating sound? Speaker location is a fun job with this model. Can be done with a sugar cube or a small round one, but at the expense of some of the weight.
Double sided adhesive foam works fine for both speakers and decoders. I use 3M brand, used for light-weight pictures and the like. Double sided sellotape works as well. Whatever you do, keep away from electrical tape. :Red Card :Red Card :Red Card
Yes, use heat shrink.
Bill, jump in whenever, I'm sure Kevin appreciates it.
Bon courage mon ami,
reposition the motor upside down, I knew that I had read that somewhere. But, is there an obvious reason for doing that, I have missed? Best wishes Kevin
Aplogies to Nigel, hopefully in peaceful sleep.Hi Nigel. Thank you. I have taken a photo and it is on an SD card. But at the time of writing, I cannot remember how to upload photos to my laptop, but I have located the “ DZ Decoder “, it was there all the time, but I kept passing it by. Best wishes Kevin
Most laptops have an SD card slot Kevin. All my business and personal machines had and my current budget HP does as well, located on one of the four edges, dependant on manufacturer. I hope yours does too, as it saves so much time in finding the camera to PC cable!
Just slide the card in and read the contenrs via the file manager. Job done.
Bon courage,
Hi Kevin,Hi Bill and Nigel. I have been reading through the Hornby guide on 0-4-0 conversions to DCC, “and in step 20†it says
Ed has this one covered regarding the motor. It's all about making things easier.
I think we all assume from your previous posts that you are going to chip a Hornby 0-4-0, as best practice before moving on to the Terrier and others.
This is a fine plan which will give you the confidence in moving forward with other locos. Don't forget to test the installation before re-fitting the body.
Onwards and upwards,
I have thousands of photographs on my PC and back-up and can find what I need due to a simple filing system.
It's fun filing photos and brings back happy memories.
Once you have the SD card in the PC interface slot, you simply open the file manager, set up some appropriate photo files (use 'open new folder' icon) and copy the photos from the SD to photo files. No password is required.
