Hornby Diesel -Old Locos
(In Topic #7458)
Increase pulling power?
Hi -Looking for some advice please. I have a stock of some 10 or so old diesel locos which are in fair working condition and could easily. I think be cosmetically improved, so worth keeping I think.I plan to continue to use a DC system.
Is there any way of increasing their pulling power- they do not come close to a new loco I have which zips up the 1 in 30 gradients I have on my layout pulling a decent long train-the older locos just about make the gradients essentially on their own! Perhaps their just aged and a bit knackered like me!
Is it worth changing the motors? If so to what?
I look forward to you kind assistance
Ian::pedal
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/606.jpg)
![Sol is in the usergroup ‘Super-moderators’ Sol is in the usergroup ‘Super-moderators’](https://yourmodelrailway.net//themes/default/images/cns_rank_images/mod.png)
I had to add about 160 grams into a new Hornby Class 73 - old Lima updated with the new motor bogie. This was before they re-issued them with traction tyres which is a backward step IMO.
Depending on the type of motor & I think, they used Ring Field, this method works well http://www.modeltorque.com.au/
Kind regards
Ian
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/2.jpg)
Most layouts have their fair share of "heritage" stock Ian ………………………:roll::roll::roll:Excellent -thanks for speedy reply -I'll try both of these ideas and if I'm unlucky with black smoke I'll call it a "heritage" loco!
Kind regards
Ian
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/11.jpg)
Buy another old one off ebay, take out the motor and fit two power bogies to each loco - might work?
Convert to DCC and double head them!
If they are Lima it is possible to purchase replacement pancake motors that are significantly better than the originals and just pop into the housing. I can find the website if that is of use. afternote: just noticed Ron (Sol) has the link to the website on his comment.
Depending upon the type of loco it might be worth looking at the Hornby Railroad range, which has a number of common diesel types - Class 20, 31, 33, 37, 42, 47, 55, 73 and DMUs with upgraded motors. You could buy these and swap chassis, although for a few extra quid you could probably buy a new Bachmann version.
Vitrains produce Class 37 chassis quite cheaply.
You could look at Black Beetle and Maschimo replacements.
I doubt any of this helps you but at least you know we are scratching our heads. :hmm
Bob
Last edit: by Bob K
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/27.jpg)
Thomas
TUTTO IN GRIGIO ARDESIA
Ian
