Everything Hornby
M7 LSWR livery and which carriages
You are saying there is no way the magnet is interfering with the loco and there is nothing obvious protruding above the rail height in that case look carefully at the M7 have you inadvertently when handling the loco dislodged some of the brake rodding from its location pins/holes and it is hanging down below the rail height.Lets also clarify when you say grounding you mean the loco is actually being slightly lifted off the tracks in that area?
Whether or not the magnet is interfering with the M7 I don’t know? But the M7 would not pass it. During a moment of departure from the wiring issues that I have, I have been considering an electromagnetic uncoupler in place of the permanent magnet. I can categorically state that the “ Brake Rodding “ is in place, and above the inner rims of the wheels. I also stated that when the M7 departed the fiddleyard it seemed to highlight a short circuit where all the Bachmann Locos and Dave Jones Locos have no problems. I sincerely hope that we can put the M7 to rest for the present. Best wishes KevinYou are saying there is no way the magnet is interfering with the loco and there is nothing obvious protruding above the rail height in that case look carefully at the M7 have you inadvertently when handling the loco dislodged some of the brake rodding from its location pins/holes and it is hanging down below the rail height.
This is a long shot but are the magnets you are using very strong? If they are and you are running the loco very slow the magnet power itself could be stopping the motor turning because of the strength of magnetism could be pulling on the wheels or other metal parts that may be on the loco. Push the loco gently by hand along the track and when it goes over the magnet do you feel resistance
I was just thinking the same thing as Brian and if your further testing shows some resistance Kevin, take the magnet out and drive the loco over the hole under power and see if it's any better.
Bon courage,
Brian. “ Not interfering “ ? But blocking the path! And nothing is protruding above the rails. Maybe I will have to learn how to do a video, once I have caught up with some sleep 💤. I have made an appointment with my GP to discuss my sleep issues. Best wishes KevinYou are saying there is no way the magnet is interfering with the loco and there is nothing obvious protruding above the rail height in that case look carefully at the M7 have you inadvertently when handling the loco dislodged some of the brake rodding from its location pins/holes and it is hanging down below the rail height.
Bob
If those are KaDee magnets they are not designed for or meant to be used with code 75 rail. Is this the 312 uncoupler? They were originally designed for code 100, from memory some baseboard should be removed for code 83, and even more for code 75. I did ask Kadee a few years ago, they confirmed this. Some random thoughts based on past experiences:
Are the coupler trip pins hitting the magnets? This is the usual source of grounding.
Aside from the issue of the BtB and brake rodding (check that it is in all the slots and not skewed), are any electrical wipers coming in contact with the magnet?
The magnet has to be centrally located.
If this is not a Kadee magnet then you need to check the thickness compared to the KD one and adjust the height to make sure the clearance between the trip pin and the magnet is correct.
A low KaDee coupler pin will usually slide over turnout frogs without being noticed. Running over a long magnet is another story.
Sloppy coupler pockets/hinges on the locomotive will allow the coupler to droop. The triangular part of the hinge should be a tight fit in its slot, if not it will slide down and the coupler will droop. Try reversing the hinge, it is handed with a small knob on one side that means it has two heights. The cure here is usually a cut-down #5 with gear box or similar, not the NEM ones. I have had this issue with both Hornby and Bachmann locomotives. Tension locks are fine with a bit of droop, not so for KaDee.
Does the M7 have a low gear cover base plate?
The Kadee system is an integrated one, use the jigs and tools that are meant to be used with the couplers, including at a minimum the coupling height jig, the centering jigs for the magnets and the pliers for changing the height of the trip pins. Buying the couplers and winging the rest usually leads to problems…Pandora's box in fact.
Another project that I am considering is a “ DC micro layout “ and maybe I will be able to run a Pug and something suitable? Or even a narrow gauge micro layout? Best wishes Kevin
Using Kadee electromagnet for uncoupling ,requires a good 18v DC 3 amp supply like a laptop type that is regulated.As it happens I have been considering the Kadee electromagnetic uncoupler, I don’t know if there is anything untoward about it that yourself or any other members of YMRC are aware of before I proceed with this project?
http://yourmodelrailway.net/view_topic.php?id=13783&forum_id=6
16v DC . not 18v
you may get away with a minimum 1.5A
https://www.kadee.com/html/309ins.pdf
16v DC, 3 amp. Or 18 v AC, 2 Amp with a DC rectifier. A veritable dinosaur that requires major track work. The Rapido one is smaller and a lot less power hungry as it uses a rotating magnet.
Did you have a look at the M7? If an old one does it have metal tension locks? Steel? From your post I was assuming a KD equipped locomotive, sounds like a tension lock one from your latest post. Check the clearance of the hook.
Hi Nigel. Thank you for your reply. Have you reviewed your opinion of the Rapido from when you replied to my thread? Regarding the M7 , I did state that I had previously removed the hook from the “Leading Tension Lock†.Best wishes KevinHi Kevin,
