Everything Hornby
M7 LSWR livery and which carriages
Hi John Thank you for your reply. Unless I am getting a loco converted for sound I use the regular decoder from Hattons. In the meantime I have emailed Dave at Roxey Moudings, regarding Coach Kits. He suggested either a "Brake third 4 C1 and a Composite 4C6" alternatively"Brake Composite 4 C18 and a Full Third 4C3". He said that some Hornby locos are variable in there pulling power. Not surprisingly he did not mention any likely problems with his kits Kevin
I didn't like the 6 wheel suspension design, but I think that's my only complaint.
Don't forget the wheels, he can probably supply the correct type - Mansell I believe.
If you do a brass kit you will need to solder it for best results.
Just one question about soldering an OO kit, is there much space to work freely inside(or do you solder the outside) oh just another thing about painting and lining? does that need a lot of skill? Kevin
I think there's a logical progression with modelling.
Just last week you were agonizing about the glue to use on plastic kits. It's quite a leap to soldering brass kits. The methodology is totally different. While plastic kits might be said to fall together when you shake the box, brass ones need a lot of finessing. Some are better than others.
You do need a good soldering iron (ie expect to pay quite a few quid for one), flux and modelling solder. You WILL singe your fingers.
To answer the question, the first rule is to work on the inside where excess solder won't show. Sometimes you have no choice but to work from the outside - then it's a bit of work to clean the surface.
I'm trying to think of a good simple kit to start you off, like a wagon. I've done a couple of Bill Bedford (Mousa models) etched wagon kits but I wouldn't say they're easy. I've got four more waiting for my attention. Perhaps someone here knows of something suitable.
My recommendation though, is that you start with the plastic kits you already have to get the feel of kit building, painting and lettering.
If your kit falls apart, it wasn't assembled properly in the first place - that's on the builder. I don't think I've had anything fall apart. Quite the contrary, plastic models can be the very devil to get apart if the need arises, sometimes you can't without destroying them.
So often I get the impression that people are afraid of solder and I usually hear the "burned fingers" refrain. I've never "burned" my fingers (implying lasting damage) but I singe them all the time.
all the best. Kevin
Replacing the bogies?or anything else? What I need to do is locate a Diagram of the 48 foot LSWR coach.
Can anyone please advise me? All the best. Kevin
Yes i understand you have cut out sleepers but is the top of the magnet well below the top of the rail height Kevin?Brian. AFAIK. I am using the regular magnet and code 75 track, cutting out some sleepers. I have inspected my M7 and not ced a wire frame ? I don’t know if this answers your question? But my Bachmann ex GWR 57xx and several 0-6-0 Locos have no problems .Best wishes Kevin
I.E. if you put a ruler across the top of the 2 rails the magnet should be lower.
On the M7 the lowest points are the brake rod assembly which is set above the rail height for obvious reasons.
Last edit: by Briperran
Yes, Certainly, Absolutely, Affirmative.
Kevin what does the above relate to as my psychic abilities are not working that well tonight
Next question the magnets you have fitted is the width of them close to the rail either side if so the wheel flange could be catching on them.
Also is your track pinned or glued if pinned are you sure there is not a pin that has not been knocked down properly.
Yes . The magnet is below the rails in a central position, but because the sleepers have been cut to fit the magnet centrally between the rails, there isn’t any track pins, that section of track is glued down. As I have already stated all my Bachmann 0-6-0 Locos pass along the track where the magnet is situated, without any faltering.Best wishes KevinBe more helpfull if you just answered "Yes the magnets are definitely below the railhead"
