D of G TTS
(In Topic #10878)
Problem
I had a mishap with my DofG TTS loco. The 2 of the tiny wires from the loco to the tender have come adrift from the small white connector under the tender. They are much to fine for me to try repairing so where should I send/take it too? Not had a problem like this before so I am a bit in the dark as to repairs etc..?Cheers
:thumbs;-):cool:
Thanks
:thumbs;-):cool:
Last edit: by Silver foxx
Cheers, Pete.
If you want to venture into repairing if you take the tender body off you can remove (unplug) the decoder and you should be able to trace the wires……..they are usually identified on the PCB board. It is very easy to bypass that fiddly plug.
On the other hand the shop can fix it
4 black wires. Presumably the decoder is in the tender with the speaker, and they are 2 power wires from the track to the tender, 2 DCC output leads back to the motor. They're supposed to be red, black, orange and grey! So much for common standards. It's only 3 months old, I'd send it back to Hattons for a replacement, it should be robust enough to take routine handling.
As they're disconnected there is no danger to the decoder. If you have a multimeter and a DC powerpack see what is coming out each wire. 2 will be live, 2 dead. Take the hood off the tender, and see where the corresponding wires go. Assuming Hornby did it correctly, what you should have in the CB is shown below. Trace the leads back to the socket, then you can match up with the leads coming out of the engine. At a minimum put a spot of paint of the appropriate color on each lead. Mind you, in my experience there is no guarantee they will have done the 8 pin socket wiring correctly. It is a bit fiddly, but the wires can be re-inserted. Red/black and orange/grey are interchangeable. Worst that will happen is the engine will go backwards. Which can be changed via the software anyway. If you don't want to do it get it done professionally.
Those dinky little white connectors are not really up to the job if the engine is handled often. It makes more sense to have the decoder in the engine and just 2 leads and connectors going back to the speaker in the tender. I've ended up rewiring all the Hornby's I have that came with this type of connector with more robust ones, and replacing non-standard wiring when necessary.
Good luck,
I have found both Bachmann and Hornby ignore the NRM colour code in places……typically between loco and tender! But they do mark the motor and left and right pick upd
Not always. If the factory is running out of red black it is. I've had Bachmann and Hornby offerings with all black, all red, black and red going to the motor from the decoder……..and black and red going from the track going to the decoder. It all gets ripped out and rewired to NMRA standards.
Ron,
I use Miniatronics 2 or 4 pin connectors with cable for going between the engine and tender. Bit thicker than the stuff Hornby uses, and if enough strain is put on they simply separate rather than pulling out of the pins. The cables are identified and there is a big white spot to make sure polarity is not reversed. I put the plug in the tender or under the cab floor and the cables look like all the pipework that went between engine and tender if separated into individual strands and bent into a loop. If securely anchored to the tender with a strap the cables will take the strain of a suspended engine. Pictures of the 2 and 4 pin connectors below.
These male/female connectors are readily available from electronic stores without cable, but given the price it's not worth getting the iron out.
:hmm :cheers:cheers
The issue of course is having all the electronics and in the tender, which for all practical purposes means a permanently coupled unit. Not easy to handle with a large engine/tender, drop the tender and out come wires. Poor design. There are better ways of connecting units. I'll post a rant, this is Ron's thread.
When it's back from being fixed, one tip is to run it onto a loco lift (Peco sell one, SL-43) and store it off track in that. No more handling engine and tender to lift it off and put back on. Good investment considering the cost of the locomotive (and its inherent fragility). I use these for my brass engine stock (steam and diesel AA or AB units), drop one of those and it's sackcloth and ashes time as there are no spare parts.
Thanks
