Couplers on Hornby diesel
(In Topic #5805)
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/27.jpg)
Maybe someone could advise?
Thomas
Last edit: by FS
TUTTO IN GRIGIO ARDESIA
Thomas
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/18.jpg)
![](https://yourmodelrailway.net/gallery/18/18_080813_530000000.jpg)
I have two of these locos both of which are like this. Unfortunately the situation is made worse by the fact that the buffer beam (not the skirt which I have left off) forces the coupling down.
Les
Devon Junction
Kernow Junction
Kernow Junction
Les
Devon Junction
Kernow Junction
Kernow Junction
I've deleted the duplicate post for you Les. :cheersSorry I was impatient and pressed the send button twice.:oops:
Les
I thought there were standards that manufacturers were supposed to be following nowadays ………..:roll:
It's a real pain when you spend your hard earned cash on a loco that won't attach to your stock - come on Heljan, get your act together :twisted::twisted::twisted:
Les
Devon Junction
Kernow Junction
Kernow Junction
I'll drink to thatThanks for the deletion Peter - it's saved my blushes. Need a drink now.:roll:
:cheers Les
Thomas
But there is a partial cure for many types and it's easy and cheap.
Heljan couplers are cranked. That is not only do they droop but they "step down" part way along the shank which holds them in place.
If you obtain a supply of Bachmann straight couplers they will be found to fit perfectly as a replacement on most types (not class 35 as that has air tanks moulded onto the coupler and unfortunately is about the worst offender for droop as a result) and will sit rather closer to the height of your rolling stock couplers.
Most of my Heljan locos operate with Bachmann straight couplers without any problem at all. Including "Westerns".
Les
Devon Junction
Kernow Junction
Kernow Junction
In the meantime I found in my spares box what I think are Hornby straight shank couplers and have plugged one of them in. The difference is amazing (new photo below) so it probably means your tip will work with them as well. Many thanks.:thumbs
Les
![](https://yourmodelrailway.net/gallery/18/18_090907_560000000.jpg)
Devon Junction
Kernow Junction
Kernow Junction
