Carriages by Hornby
(In Topic #13703)
Are any of them similar to a particular diagram
Hi All. This subject may have been touched on previously? But, in my headlong dash to get back into model Railways after 40 odd years, I wrote to Hattons, and purchased some green carriages and a school’s class Loco. Whosoever packed my carriages got into a right old pickle and I ended up with more brake carriages than required? Anyway is there anyone on the YMRC forum that could identify these carriages for me. Best wishes Kevin
If they're green Kevin, they'll do for Southern Region - no class down there ! ……………………![]()
Oi!!!
:tongue :tongue :tongue
Bon courage mon ami,
:thumbs
You did say Hattons. You could just go on line and look at SR coaches. Should give you an idea.
Hopefully not long now until you can get to your railway.
After this, Kevin, I am surprised you are still talking to Monsieur Le Mac!!
Bear in mind the Southern Railway (and its predecessors) and BR Southern Region kept coaches in semi-permanent sets until the 1960s, with each set of more than two coaches having two brake coaches, one at each end. Single coach trains were also usually a brake coach (most usually a Brake Composite). The Atlantic Coast Express was infamous for having more brake coaches than "ordinary" sitting coaches, because there were so many portions to split off along the way.
For model railways with limited space, the typical 3-car sets are ideal, so for those you usually require two brake coaches and one composite. 2-car sets were more variable, but could be a Brake Composite and a Brake Second (Third in earlier times), or a Corridor or Saloon Second plus a Brake Composite, or a Composite (or Second class only for branches where first class was not an option) and a Brake Second.
This is by no means exhaustive, but typical formations suitable for a model railway would be, using standard nomencaltures:
5-car: BSK+SK+CK+SK+BSK
4-car: BSK+SK+CK+BSK
3-car: BSK+CK+BSK
2-car: BSK+BCK or SO+BCK or CK+BSK or SO+BSK (2nd class only)
Single car: BCK or BSK
For pre-1957, substitute 'T' for 'S' (i.e. Third for Second class).
For later Bulleid coaches, there were Semi-Open Brake Seconds, but they simply go where I have typed BSK.
The usual problem for Southern modellers was that Hornby (and Bachmann) tended to NOT do enough brake coaches!
Anyway, here's a photo of a train currenty running on Newton Broadway, made up of two 3-car sets, so four brake coaches (BSK) and two composite coaches (CK), one Maunsell set, one Bulleid 'multi-door' set, all Hornby. Merchant Navy 35005 'Canadian Pacific' is temporarily pretending to be a 1950s version in blue, awaiting the arrival of Hornby's 35024 'East Asiatic Company' in original form in blue.
Last edit: by SRman
Otherwise, talking generically, so to speak, I gave you typical set formations earlier and you could make up those sorts of sets from what you have.
