Another Hornby van modification
(In Topic #6183)
From The Railroad range
Before![](https://yourmodelrailway.net/gallery/95/95_302317_440000000.jpg)
Started life as R6474 from the railroad range
stripped to bare chassis
![](https://yourmodelrailway.net/gallery/95/95_022125_000000000.jpg)
added bogie bolsters, centre sill & base for Kadee couplings
![](https://yourmodelrailway.net/gallery/95/95_022125_000000001.jpg)
Painted, Kadees fitted #148 in #252 boxes, renumbered the van, bogies painted & dullcoated the lot. Weathering to be done later.
![](https://yourmodelrailway.net/gallery/95/95_022125_010000003.jpg)
I'd guess, if you're going to "do things" to these Railroad range items, they're probably quite good. Cheaper than the current stuff and a few years ago, were considered "top of the range".
My next one will be another VDA 4 wheeler but with Bachmann bogies.
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/465.jpg)
Stu
In most cases, lining the chassis up with bogie installed , against a Kadee coupler height gauge #206 , gives a good indication.
![](https://yourmodelrailway.net//data/external_url_proxy.php?url=http%3A%2F%2Fkadee.com%2Fhtml%2F206c.jpg)
The end of the lid as above is the height required to mount the coupler box. Occasionally, using their fibre washers #208 or 209 on bogies screws or gear box shims #211 is used to get correct height.
On a previous Hornby VDA van. I had to remove some chassis at the buffer beam to get the box high enough.
I was asking as the picture sequence seemed to show you'd strip the chassis then added the bogie mounts and Kadee ( no Y) mounts at the same time at the correct height ( which I thought was quite impressive).
Stu
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/401.jpg)
Are you going to weather it Sol?
