Install a decoder in a Hornby tender-drive loco
(In Topic #6291)
What needs isolating?
I have a very old (30+ years) Hornby A4 tender-drive loco into which I'm considering installing a decoder. It has a Ringfield-type motor.The loco body is connected electrically to the tender by a metal pin and a sort of 'pronged' metal clip. This means that one brush is supplied from the loco wheels and the other is supplied from the tender wheels.
There is loads of room in the tender for a decoder, and I would be quite happy to change the connection between the tender and the loco body to a hard-wired one if that would be better electrically.
What, if anything, needs to electrically isolated when I install a decoder?
Perry
Three things are important.
Make sure the motor brushes are isolated from everything.
Make sure that the pickup wheels are isolated from each other. It sounds obvious, but sometimes the body can cause short circuits on these old locos.
Cut the capacitors off the motor.
:cheers
Perry
I hope this helps a bit and is not too confusing.
[user=95]Sol[/user] wrote:
Many thanks Ron, Thats saved me a headache! :thumbsDerek, that does not matter as long as any lights & motor are completely isolated from the chassis with any wiring for lights & motor only coming from the decoder.
Last edit: by shunter1
