Electrics. DCC
Decoder fitting
Hi Nigel. With all my "Faffing Around" . With Hornby 0-4-0 's . I have at last got down to the serious business , today I "Plumbed in" so to speak my new "DJM Electric Loco" 5003 of course I cannot put it through its paces, but it has a terrific compressor sound. I may even get around to working on some other projects. It has been unbelievably hot,I will be glad when the "Thunder Storm" gets here. All the best. Kevin
On a more positive note, Nigel has hit on another idea that would improve reliability even further: that is, permanently attach and wire a coal wagon with extra pickups fitted. Not only would that give you space for a decoder with sound and speaker, but it would also give a much longer wheelbase for picking up electricity over points and crossings.
That's the problem with what start off as seemingly simple projects … they can grow and develop!
Modelling Tips | End Of The Line Hobbies
http://www.members.optusnet.com.au/nswmn1/ExtraPickUps.htm
Wiring a flat truck to an engine? (or anuthing else that requires power) - I use Miniatronics 2 or 4 wire cable with male/female connectors. Two for the pick-up from the wheels (which you will have to fabricate, I use copper clad ties fixed with CA and 15 thou' P/B wipers), 2 for the speaker. Rated at 1A, so good for most modern motors. You can get similar in the UK. Suitably looped they look like pipes. Fix a plank over them between the locomotive and the truck and they disappear
2/ C R
3/ G E R
4/ G W R
5/ M R
6/ B R Blue Diesel
I will test these once I have found out their age, in the Grand scheme of things. Kevin
Eileen's Emporium has the male and female plugs, just wire them up. Works best if you take the strain at one end with a plastic bar and crews over the cabling.
I'm pretty sure Miniatronics will do mail order, they really are some great connectors, more robust than the ones from EE.
Press "Prog Escap". several times that is what I didn't see in the manual. Kevin
Second place, so far, 52251 c/o Janiceand cliff. There were others that were DCC fitted, but without noticeable improvement ? And the "jury is still out". Kevin
Maybe not so fair dinkum Kevin, as Hattons are currently selling them off at £19.00 (just less than $32 Australian).Hi Ron. I have just looked at the Hornby Collectors Guide, and there is a bloke in Queensland, who is offering a 0-4-0 Blue Shunter (R 3065) just like one of my selection( could be newer?) for $84.00, fair dinkum I thought that I had just purchased a heap of junk?All the best. Kevin
http://www.hattons.co.uk/36002/Hornby_R3065_Class_06_Shunter_06008_in_BR_blue_Railroad_Range_/StockDetail.aspx
CR pug with crew and DCC fitted at £24
http://www.hattons.co.uk/291782/Hornby_R2672_HX01_Class_0F_Pug_0_4_0ST_272_in_Caledonian_Railway_blue_Railroad_range_Pre_owned_/StockDetail.aspx
Right, back to the gardening!
And I have read that the suppressor is unnecessary with DCC. Please advise. Kevin
I always get rid of the suppressor circuit, as I always strip down to basics (motor and two terminals) when doing a conversion.
