DCC to 'N' gauge using Bachmann E-Z Command
(In Topic #6258)
I have now bought an additional two 'N' gauge Loco's, a CL58 from Dapol & a CL60 by Bachmann/Graham Farish..
The Dapol's are supposedly straight forward & DCC ready, a 6pin plug-in decoder but the CL60 requires a decoder that you wire to 2 solder tags.
I could only get 1 Bachman E-Z decoder, all the DCC decoders seem to be in short supply?
Anyway, I fitted the decoder to 66111 & assigned it to No3, the default number. Hey presto, the lights came on & changed with direction selected…..BUT, I cannot get the loco to move?
As i have previously assigned 5 x 'OO' gauge Loco's on numbers 1 - 5, is this why I am having trouble? Does the E-Z Command need re-setting in some way? Any idea's on where I am going wrong?
The CL58 is indeed a delicate Loco. Plugging the decoder in was tight as there is a socket very close to the DC/DCC socket. I may stick with DC for now & gradually swap to DCC when I learn more. I may ask for help on some of the bigger forum's, too
Sounds like no connection to the motor. Presumably it did work okay before fitting the decoder?!!Anyway, I fitted the decoder to 66111 & assigned it to No3, the default number. Hey presto, the lights came on & changed with direction selected…..BUT, I cannot get the loco to move?
I would try wriggling the decoder a little with the body shell off and the controller set for motive power.
You are not going wrong. What you have done is just fine. The E-Z does not need resetting.As i have previously assigned 5 x 'OO' gauge Loco's on numbers 1 - 5, is this why I am having trouble? Does the E-Z Command need re-setting in some way? Any idea's on where I am going wrong?
I have a small N layout with a couple of Farish models - one with a socket, and one with solder pads. I have fitted decoders to both and use the E-Z controller without problems. I also use the E-Z at other times for some of my 00 testing, using the same loco numbers. The controller has no memory of how it is used from one layout to the other. It just sends signals out to the track with the address of the selected loco number assuming that there is a loco out there with that address.
Once you have got this sorted, we need to help you more with fitting the decoder to the loco with solder pads. 2 are not enough. Needs to be at least 4, and more if there are lights as well. Could be a total of 6 or 7.
did any other loco move when you set no 3 ?
lol::lol::cool:
Owen, I think he is using the E-Z on two different layouts. 5 locos on the 00 layout, and so far just the one loco on the N layout. So there will be no problem having a loco on the 00 layout with the same number as the one on the N layout - always assuming that the E-Z is only connected to one layout at a time!!Barrysrailways1, you said you have numbered loco`s 1 to 5, is that 12345? as you cannot have two loco`s numbered 3
did any other loco move when you set no 3 ?lol::lol::cool:
:thumbs:lol::lol::cool:
