wiring hornby point motors
(In Topic #7949)
I'm in the process of building an exhibition layout measuring 8ft x 2ft plus a fiddle yard at one end.The trackwork consists of a single track which enters from the fiddle yard through a tunnel the first point splits the track so that two resulting tracks go either side of the station platform, there is also a runaround loop running off these two tracks via two crossover points at the platform end of the terminus station.There are 10 points in total. What I want to know is, how do I wire these points using a CDU and taking into consideration that I want the two crossover points on each platform lines to work simultaneously? (together via one switch each).It would be great if someone could help, even better if you could provide a diagram. :roll:
Have a look at the Brian Lambert web site which contains all the information you need including diagrams.
http://www.brian-lambert.co.uk/Electrical.htm#Points
