Thought I was saving money!
(In Topic #9338)
Transformer problem
I saw a "transformer" listed on amazon, 240V in 12V @ 4.9A out, - for lighting £3.94It arrives, I connect it up to a controller, locos travel in spurts and the "transformer" clicks in time with the spurts. Suspect I have some electronic convertor not a conventional inductive type. Any suggestions, ideas (apart from bin it?
I'm no expert, but assuming 4.9A is 4.9Amp at 12 volts, sounds a bit high to me.
Most Model railway transformers appear to accept a load of about 1Amp and 16/0.2 wiring is only rated at 3Amps.
Could be 'not fit for purpose', but there again I might be totally wrong.
Last edit: by Ed
I have now gutted a wall wart of it's rectifier and taking a switchable direct AC output from it, I want it to power my running in oval; one advantage I've already found is that I can switch the output voltage down, which is very handy for some of the Dapol and Union Mills jack rabbits.
http://www.ebay.com.au/itm/AC100-240V-DC12V-5A-Laptop-5050-LED-light-charger-Supply-Adapter-Power-Cord-AU-/170846394810?pt=AU_Laptop_Accessories&hash=item27c73d19ba
Last edit: by Chinahand
