isolation switch illumination
(In Topic #8402)
old board showing point positions and isolation switches..
EDIT:..Ok … have found some info on forum and brian lamberts model rail site :oops:,if i read it right i need DPDT…ON/ON switches.. to combine (using one switch) for isolating rail switching and control leds using a seperate 12v supply tapping of as required.
question!!…should i supply the 12v from its own transformer or can i take it from the 12v supply into the micro-miniture point/route set position led controller:hmm
Using toggles like you have ( I used pushbuttons), the position of the toggle lever is normally adequate.
Yes, then a DPDT is needed- one set of contacts for the isolating rail connection and the other for LEDs.
But outside of that, not knowing the circuit of the "micro-miniture point/route set position led controller", I guess it would be OK for the panel LEDs to use the same 12v supply making sure that the LEDS are either 12v type with inbuilt resistor or at least a 680 ohm resistor in one of the LED power wires.
