Colworth direct drive DC controller
(In Topic #13036)
While rooting around in some boxes I discovered a Colworth direct drive DC controller ?
Its a panel mounted unit that i used many years ago.
However I have no idea what the input voltage should be & can't seem to find any information anywhere on the net.
Can anyone shed some light or have any information relating to the unit ?
Thanks.
Tony.
Regards.
Tony.
Regards.
Tony.
Here are a few photos.
There is some writing on the back but its long since faded.
It looks like use "something" supply DC ?
When I get a chance I'll try a DC adaptor & see what happens ?
Tony
Regards.
Tony.
Regards.
Tony.
Yes. There is no transformer, so I think that you are right. No AC house power.
The 2 N 3055 transistor (with its heat sink), is the give away.
If you have a variable output 12 Volt DC power supply available, connect a mulitimeter set to DC Volts to the output, and start with both control knobs set to off and slowly wind them up.
If you're going to put it into service, a laptop charger as a power supply, is ideal.
They are available on ebay pretty cheap. For example . . .
Pardon our interruption...
I'll see what I can do with it later.
Tony.
Last edit: by amdaley
Regards.
Tony.
Regards.
Tony.
I'll use it on my study test tracks so I won't need to go downstairs every time I want to test a loco.
Here's a photo of my study test tracks.
Dc in front & DCC at the rear.
Tony.
Regards.
Tony.
Regards.
Tony.
If you're going to use it on your layout, check that the adaptor can supply at least 1 Amp.
Five would be better.
Its 1 amp Max.Looks good, Tony. :thumbs
Its only for testing locos on my test track.
Tony.
Regards.
Tony.
Regards.
Tony.
