NCE Powercab
I have done this before, but, I have had too many bumps on my head
OK Kevin , let start at the beginning.I am assuming you want to change the address from the default short address of 3 which all decoders have at the start and that is what you are reading at the bottom of that first page - the address is Short & asks you if want to set up the ADR ( meaning the new address) and if you do, press 1 then go to the next page to change it to either a new short address or a long address.
Now if you do not want to change an address but just run a loco that you have previously either left as 3 or changed to a new number, just put it on the track, press Select Loco button, press the digits representing the address then Enter & it should run.
To set up the address at this step, press 1, allowing you to change the addresses (short and long). If you are satisfied with what is already set up, press enter.
Last edit: by SRman
Hi Jeff. Thank you for your reply. Does that mean I am being told by a lump of plastic ( Handset) . Oi you, you have already set up this Loco?
Yes, but by pressing 1, as per my previous post, you can change the address.
I will have to be certain which number I used in the first instance, and should I use the unit number, or something else. You seem to have so many Locos and you use Powercab, or do you select certain Locos for each film. Best wishes Kevin
I have many locos and units. The ones in use at any one time are stored in the NCE recall memory slots.
I have several rules for choosing numbers, because not everything falls conveniently into one numbering scheme. Even so, there are occasionally duplicate numbers, so I have to work out a new rule for those cases, or renumber one of the offending items.
Rules include:
Locos or units with low numbers use short addresses. This also applies to SR locos numbered in the 300XX series, such as M7 30051, which takes the short address 51.
Locos with longer cabside numbers such as steam locos or some of the European locos use the last four digits of the number (not including check digits), thus Bulleid 35007 becomes long address 5007.
BR TOPS numbered locos use the class number and last two digits, skipping the middle digit. 66 022 becomes long address 6622. Unfortunately, that clashed with 66 522, so I had to choose a different scheme there - I renumbered 66 022 to 66 089, so it took long address 6689. Class 455 835 becomes long address 5835
Pre-TOPS diesels and electrics had one to four digit numbers, so those are easier - D7658 becomes long address 7658.
Industrials are numbered in their own short address scheme with numbers below 30, so they all get short addresses. No. 8 clashes with LT Bo-Bo electric loco No. 8 'Sherlock Holmes, so that has short address 108 - NCE can use addresses up to 127* as short or long addresses, you choose.
Other clashes can occur - Merchant Navy 5012 clashes with class 71 electric E5012. At present both use long address 5012, but the electric will get renumbered eventually (easier than renumbering and renaming the MN).
This all works with my Power Pro 5 amp system, but the Power Cab deals equally well with this.
I keep a spreadsheet listing the address, loco/unit cabside number, functions available (e.g. F0 - F3), a brief description of the item, the brand of the model, the brand of the decoder and the number of pins or 'HW' if hard-wired.
* NOTE: if using long addresses below 128, the NCE will put a star before the address on the display to indicate it is a long address.
Last edit: by SRman
I have some Hornby Locos which are still DCC , and others which have decoders . But something has happened?
Those numbers didn’t pop up on the screen of the Handset, when the Loco was put on the track, when I pressed recall. Best wishes Kevin
First some help from Mike (16A). Sadly no longer with us, but his words live on in the forum. He said :-
"Kevin
(1) Decide which locos you want to use for the day (forget recall stack for the time being).
(2) To select first loco Press 'Select Loco' + Enter a loco number + Press 'Enter' and you have control of that loco so, set it running.
(3) Whilst that one is running 'Select Loco' + Enter a loco number for a second loco + Press Enter… you now have control of the second loco.
(4) To regain control of the first loco either repeat what you did at (2) or Press 'Recall' and the first loco you chose will be the second on the list, scroll down to it, then press 'Enter' and you have control of the first loco again.
The recall stack is a list of the last six locos you selected/accepted - nothing more, nothing less. Powercab adds a new number automatically everytime you select a loco and at the same time it gets rid of the sixth number.
If you select loco No 99 six consecutive times and then go look at the recall stack, it will show a list of 99, 6 times.
You can use either method… whichever suits you best…..".
( Back to me) :- Wise words from Mike So follow his guide and try one of your locos to see if THAT works.
Ok so maybe you cant remember the locos number ?
Step 1)…….. (please remember bite size chunks, cuppa tea in between !) :-
Using Mikes notes above, lets TRY 3 as the loco code, maybe its reverted to factory set code, or try the 4 Diggit number from the cab side of the loco . . . . Didn'twork ?..no problems :-
Step 2) Rubbing my Crystal balls, I can tell you that you WERE using 4 diggit addresses and that you had
An 08 diesel set to code 8691
A Pannier Tank set to code 1294
A Pannier Tank set to code 6422
Unfortunately when I asked about the Thumper me balls went cloudy and I got no reply !
But in theory it should be the units 4 digit number ? If its a five digit number try dropping the middle digit. So again using Mikes wise words above as a guide try entering THAT and see if it works. didn't work ? No problems :-
Step 3). So we need to find out what the loco has been coded as, Lets turn to a guide that was put up by Nigel
( BCDR) For you in a previous topic. It's a guide to setting the loco's code for the first time, but if you follow his guide it should also just show you what code the loco has NOW
LINK :- http://yourmodelrailway.net/view_topic.php?id=14935&forum_id=10#p270587
Give that a try and see if it tells you what code is already programmed into the Thumper, then go back to Mikes guide and try THAT code.
And remember, 3 Steps - that should be at least 3 Cups of Tea ! And one afternoon snooze :thumbs
