MERG DCC Kits
You're now entering the area I have yet to get into.
Constraints I see so far (I may well be wrong, and if so hope someone can point me in the right direction), is only one controller can be in control of a locomotive, so if your throttle is driving the loco, the the automatic control cannot.
So far I have got to the point where I can either control turnouts via the hand throttle, the JMRI mimic panel via a mouse, turnout tables or route table.
I need to install blocks and block detection, which will involve a partial rewire. Then signals, the signals will be interlocked to the points and block detection, but initially, the driver will have to obey the signals. Eventually, I intend to have some DMU's running under full computer control, while loco hauled trains will driven by an operator, shunted within the platforms and returned to the fiddle yard. Both automated trains and operator driven trains obeying the timetable sequence and signals.
I've still a fair learning curve to climb.
Paul
Only one controller can control a loco at a time.
Unlike DC, where you just kill the power to the track to enforce a Red signal, I'm not sure how to enforce a Red on a loco thats being controlled by a hand throttle.My own answer is that is the loco drivers job, as to me DCC, is there to allow you to drive the loco rather than switch the power to areas of track.
Sorry if that doesn't answer the question ….. again others may have the answers as I'm still fairly new to this computer control malarky - I have to stay a couple of chapters ahead of Toto
Paul
Last edit: by paul_l
does not appeal to me, washing machines are okay being automatic. Real trains or models need a driver:lol:, I am interested in the idea that(if I take my eye off the ball) a train will not overrun a stop signal;-).If I was to join M E R G , would it be possible to use their equipment to stop trains at signals and points without the aid of a computer?? (I have nothing against others who use a Computer) but I want to be the "Fat Controller" and every other grade on my railway. If I can combine M E R G equipment with "Wire in tube point control" everything will be hunky dory with me. Kevin
Don't know about other makes of command station and decoders, but this is how it's done with Digitrax equipment.
KB193: Brake Sections
No computer involved, but still complicated (well it is to me) and no MERG kit either so apologies as it's a bit :off topic
I have not a clue what is going on here, but I am enjoying the read. Hoping to learn something along the way.
Stephen
When a human is controlling a loco, he can usually ignore signals; but it is possible to set up protection devices linked to the signalling system to protect the loco from its driver.
They are many and varied.
Ed's Digitrax is an example.
My advice to Kevin would be to not try to run before he can crawl. Start with a simple project and build up to the complicated.
Kevin
Looking at Ed's post, and a bit o googling, dc braking on a dcc system, appears more a feature of the loco decoder than the DCC system.
DC operation mode on the decoder must be set OFF
The section of track prior to the signal needs to be fully isolated (double breaks at each end).
For 00/H0 the isolated section needs to be able to be switched between DCC Track feed and 12V DC, a dpdt switch or relay would suffice.
When the signal is clear, then section is connected to the dcc track supply.
When the signal is at danger then the section is fed from the 12V dc.
When the loco enters the section supplied by the 12V dc, the loco will decelerate to stop, controlled by cv4.
When the signal clears - section now fed by the dcc track supply the loco will accelerate back to the previous throttle setting, the acceleration rate is controlled by cv3.
Isolated section needs top be long enough to allow the loco to stop before the signal. Double heading may cause issues as locos that have not entered the isolated section will still keep pushing.
So if you are wishing to avoid any computer control, then a simple system using switches and relays will do the trick.
Paul
