DCC Tutorials Getting you started
(In Topic #13219)
Absolutely to hard wire my first Loco to DCC
Hi All. I am just about to hard wirie my first Decoder. But although I have a test track wired into my layout, I cannot get my head around testing the Loco , for example, why is the current supply any different to that on the main ?All the current is supplied from the same Powercab handset. Best wishes KevinPS “ absolutely “ was not my intended word, my iPad is selecting the wrong words, it just don’t make sense
As you have a NCE Power Cab, the section in the manual Use Program Track, ( maybe Page 46 in your manual) explains why the difference in power between programming and main tracks.
And the test/programming track doesn't test the loco but the decoder.
NCE gives you the option of programming on the main (while running) or on the program track (not running). The program track option limits the current such that the locomotive does not move. It still receives the binary signal as normal. The current required to overwrite the eprom with the new binary code is minimal. At most it will twitch as the CVs are changed and there is a momentary current spike, especially when changing the motor parameters. More pronounced in my experience when a capacitor is present (stay alive).
Use the programming track mode (page 46) as doing it on the main can get disconcerting on an end-to-end layout. I use the rolling road for doing that.
Do not use a power booster with NCE.
Is if you program on the main it is possible that you can inadvertently program every single decoder that is present on the layout for example if there were 20 locos sitting on the layout you could change a setting on every loco which you obviously dont want to do.
If you have a programming track that cant happen you only program the Loco/decoder that is on the programming track.
Hope that helps you understand why you need one.
I just looked and my terrier decoder is in the cab but bear in mind i fitted that decoder probably several years ago and smaller decoders are now available so there may be enough space elsewhere in the loco body.
Converting locos which are not dcc ready is the same as most things the hardest one to do is the first one.
Thats why i am saying go for an easier one first so not to knock your confidence.
Current is restricted but not a single fixed limit value.
The initial (not completely clear) NMRA Standard suggested some sort of energy limit (current*time*voltage).
With the advent of sound decoders, practice had to be modified to deal with greater current drain, particularly at startup. Many older DCC systems had trouble, leading to the development of add-on "programming track boosters" (never use one with a Power Cab).
The NCE Power Cab seems to have earned the popular reputation of having the best-in-market programming track circuitry, compatible with the widest range of decoder bands models (with SPROG a close second).
However the use of a single booster output switched between main and program modes is a problem; high risk of a situation where every loco on the layout is accidentally reprogrammed plus the risk of an untested decoder installation being damaged by full power instead of programming power.
For that reason the low cost of the add-on NCE Auto-Switch is very strongly recommended:
<https://sites.google.com/site/markgurries/home/nce-info/nce-accessories/nce-autoswitch>
In a small layout you can use whatever track is convenient that is receiving power (i.e. the layout is the programming track). I use the bit of track closest to the input wires from the controller. The programming signal goes around the whole track when you are running the locomotive anyway. All that happens in programming track mode is that the current is reduced below the limit for running the locomotive. Just make sure you only have one locomotive on the layout otherwise they will all get changed.
As Ron has pointed out playing around with boosters is not required or recommended for an NCE system. I sometimes have problems with some of the old decoders (such as some Digitrax ones), where the NCE system will not read back any changes to the CVs or the source and type of decoder. Most of the time it actually rewrites the CVs. I have never had any problems with decoders from Lenz, ESU Loksound, Soundtraxx or QSI. Sound or no sound.
The NCE system is deliberately intended to be user friendly, if you follow the instructions in the booklet it works without any hitches.
I just reread your first post. Hard wiring a decoder*. Old school then. Some heat-sinks on the wires should keep you out of trouble. I use metal clothes pegs.
*I don't but that's me.
With my Power Cab / Power Pro systems, I always make sure I have set the programming output first, before placing the loco on the track.
We have discussed the Terrier hard-wiring by PM, but for the benefit of others here, I have done three Terriers, all using TCS Z2 decoders, although nowadays, I would probably go for the even smaller CT Elektronik decoders. The first two Terriers have the decoder threaded up through a slot drilled under the firebox door, sitting vertically in the cab between the driver and fireman. The third and most recent one I did has the decoder sitting flat on top of the motor, with a strip of thin plastic card (20 thou) sitting on the motor to prevent the decoder or wires slipping into the armature and stopping the motor. This last one is a lot neater because I didn't need to modify the Terrier body at all, and also makes separating the body and chassis a lot easier.
:twisted: :twisted:
The other way is just to use a short section of spare track slightly longer than your longest locomotive, and to connect the PowerCab via the ends of the rails using crocodiles. If I use mine it's so I can program the locomotive in real time on the rolling road. That way everything on the layout is running track, no messing around with an isolated section for programing that has to be switched back.
A programing track is essential if changes to a decoder are required when the layout is in operation. NEC is American, the assumption is that it is a 30 x 20 foot layout, multiple operators, with room to spare for a programing track. Usually the RIP spur which usually has a few freight cars doing nothing. IMO a programing track is best kept well away from the layout, especially if it is a small one.
Your fiddle yard to be would be the ideal place for a bit of programing track. Tucked out of the way, no chance of doing damage to the scenery with errant elbows, dodgy digits/fumbling fingers or wayward wrists. Or flying feet for that matter.
