Sound fitting a Bachmann prairie
(In Topic #11701)
Colin
Should be on Google Bachmann loco decoder &C.Vs.
Hope this is of help, writing on tab bit limited on use.
Enjoy Forums
Best of Luck
Dave D.
I haven't done this particular Loco' but have put in quite a few. I find that a Zimo or CT sugar cube speaker will fit most models, and if not you can cut down the enclosure, which I've done more than once.
The sugar cube speakers can usually be hidden in a smoke box or the bunker.
I think your best bet is to take off the body and check it all over.
Must go, battery running out.
I've done a DCC unfriendly installation (DCC socket but no room for a decoder), and the TCS website has a Bachmann 45xx installation - http://www.tcsdcc.com/Customer_Content/Installation_Pictures/HO_Scale/HO_Search/search.html - which is a hardwire. I'll dig the beast out of storage tomorrow and have a look to see what I did.
From memory I binned the existing board, hard-wired an 8-socket wiring harness, and then installed a small decoder. No sound, although a smallish sugar cube should fit in the boiler, or a regular speaker in the cab.
Found it. Looks like I did a fair amount of work to this one. Bachmann wiring removed, board screw pegs filed off. Digitrax SDH164 sound decoder with GWR 57xx sound files (public domain) loaded. Must have been short of the readies at the time. Decoder is in the cab/bunker. One speaker on the roof of the cab, facing down, second speaker in the smoke box also facing down. Stay-alive underneath the decoder in the bunker. Cab interior spectacle plate removed to make life easier. You can't see the back-head anyway, so no loss.
Hole and slot drilled through the bottom of the smoke box to allow sound out. Slot is not visible from the outside. Acoustic foam used to ensure no sound leakage. Standard Digitrax 9 pin connector hard wired to pick-ups and motor. Enables a decoder swap with no soldering. Driver George and Fireman Fred at the windows would mask the work in the cab.
There are some options with this model. A small N-scale decoder or one of those direct plug decoders will fit in the space occupied by the board/pegs, or the solid bunker weights can be milled out and the decoder put in there. The speaker in the cab could be on the floor facing down (suitable holes drilled in the bottom) with the decoder sitting on top. I've used this approach with the Bachmann 56xx. I think I'll do that on this one as well.
The body unclips in this model, 2 catches bunker ends, the stays at the front from the bottom of the smoke box to the front plate need to be detached as well. May need an artists pallet knife and a bit of persuasion to get the body off. This sort of modification will of course void any warranty.
Bottom line - it's possible to get a full-sized HO/OO decoder, 2 speakers and a stay-alive in this model without too much difficulty.
Photo 1. Decoder in cab, resting on stay-alive in bunker. Kept in place with DS foam tape (3M).
Photo 2. Speaker on cab roof underside, held in place with DS tape. Holes in underneath of bunker are to allow sound out. Real coal on top. Note butchery when internal cab spectacle plate was removed.
Photo 3. Speaker in smoke box. Hole and slot drilled/cut to allow sound out. Smoke box plugged with acoustic foam (bottom of photo, just visible).
Thanks. Probably the first sound installation I did, threw everything at it. Bet there's a kitchen sink in there somewhere. I'd do it differently now. Picked up the model for less than 50% retail, so no qualms about butchery, holes etc. Issue I'm looking at now is conversion to EM gauge. £87.60 for the wheelset. And I have 2 of them. Hmm.
Hope Colin finds it useful as it's a straightforward conversion.
Colin
I would imagine nearly all N-scale/minidecoders would fit in the boiler/smoke box space. For that matter, an N-scale one should fit in the bunker. If you used a 6-pin connector or hard-wired it that would keep space requirements down as well. Which would leave plenty of space in the bunker for the speaker (you can see where I'm going).
Colin
Well done, glad it was not complicated. One thing I did on the Class 56xx which has the speaker and decoder in the cab/bunker was to connect the speaker to the decoder with 2-prong miniature plugs/sockets and leads. That way the decoder can be removed without pulling the whole lot out (speaker on the bottom, fixed, decoder sitting on top).
